lower hinge slop
Old Jul 15, 2004 | 07:59 AM
Tim Hunsinger's Avatar
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
lower hinge slop
I've read through the archives, forgive me if this is a repeat post...
I've just replaced the pin/bushings on my door (just bought a used Camaro) that were very badly worn. I'm ordering a top hinge repair kit also. The problem on the bottom however is the pin does not rotate like it should--in other words, instead if movement between the pin and the bushing, I have movement between the door half of the hinge and the pin. Im sure the hinge is probably ovaled by now, and of course it is welded to the door (thankyou GM !). Any suggestions on a fix for this?
Thanks for reading.
Veaceonee
Sep 29, 2016 08:15 PM
Antips16
Oct 30, 2015 06:42 PM
jbates346
Oct 21, 2015 01:50 PM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
codeysabatini
Sep 20, 2015 11:36 AM
