fabric question
Old Jul 20, 2004 | 09:25 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
fabric question
im getting one of those ABS plastic headliners. im wondering if i need headliner material or will any fabric from a store work? and should i get the padding to go between the fabric and the board or will just the fabric be ok?
Old Jul 20, 2004 | 10:39 AM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
Is getting the headliner already covered not an option for you? I just got mine already covered so I wouldn't have to worry about it.
Old Jul 20, 2004 | 10:40 AM
drdave88's Avatar
Engine: 6.0L
no im not going back to any factory colors
Old Jul 20, 2004 | 10:41 AM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
Hey, I just noticed you're from Holland. Where did you get your subframe connectors welded in at or did you do the work yourself? I'm looking for a place to get some welded at but I don't want to have just anyone to do it.
Old Jul 20, 2004 | 10:53 AM
drdave88's Avatar
Engine: 6.0L
i had a guy i used to work with do it. he did a decent job, but nothing spectacular. if youre in holland, go to jeanette automotive on chicago drive. i worked with the owner a lil while back. he knows me well and they do great work with welding there. one of the guys is a master certified welder. IM me if you want his number and stuff.
Old Jul 20, 2004 | 04:21 PM
Kandied91z's Avatar
getting ready to tackle that myself. so long as your board is correct, assuming you have a headliner board or will get one since your removing the plastic one the rest is up to you. i'm using suede on mine.
Old Jul 20, 2004 | 11:54 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Hancock fabrics sells the headliner material in various colors with the foam backing already attached. So do a lot of fabric places.
Did mine a few years ago on a '78 Camaro. Worked fine.
Jim.
Old Aug 22, 2004 | 09:27 PM
kewl_blades's Avatar
Car: 2x1991 & 2000 Camaros
Engine: 350, 305 & LS1
Transmission: TH-700R4 and 4l60E
https://www.thirdgen.org/techbb2/sho...=ABS+Headliner
Warlocksirix
Sep 3, 2015 12:26 PM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
