Mechanical to electronic speedometer
Old Aug 2, 2004 | 11:32 PM
catc's Avatar
Car: 1985 Trans Am
Engine: Chevrolet 355
Transmission: Borg Warner W.C. manual cog
Axle/Gears: B W 9-bolt 3.45 Limited Slip
Is it possible to switch from a mechanical speedometer(85 Trans AM) to an electric type from an (88 GTA) without replacing the entire dash wiring harness?
Old Aug 3, 2004 | 10:32 AM
dd85T/A's Avatar
Car: 85 T/A
Yes. I swapped mine in my 85 to a 87 or 88. You will need to repin the connectors or cut and splice the traces on the flex board. I did the cut and splice. You will need an electric sender and a buffer box. Don't forget to connect the signal to the ECM.
Old Aug 3, 2004 | 12:14 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
http://www.hioutput.com/tech/speedo.html
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
