RPO Codes (unavailable)
Old Aug 30, 2004 | 04:27 PM
gowman's Avatar
Greetings. Does anyone know where I would be able to locate RPO codes that are not available in the RPO Database? I have 6 codes that I am trying to locate with no luck. They are E7Z, MX0, M0D, P84, UUB, and 1HV. Thanks for the assistance.
Old Aug 30, 2004 | 04:52 PM
87F383's Avatar
Car: 87 Formula 350
Engine: LS1 in Progress
Axle/Gears: 3.70 9 bolt
I believe MXO is an automatic transmission specifically the 700R4.
Old Aug 30, 2004 | 06:25 PM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
Does your car have the Bose stereo? If so, UUB is actually UU8.
Old Aug 30, 2004 | 07:03 PM
gowman's Avatar
Yes it does. Thanks. That is another one down.
Old Aug 30, 2004 | 07:37 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
when i decoded a friends some 0s looks like Os and vise versa.
just read them more carefully and u should find em all.
Old Aug 30, 2004 | 09:36 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
MX0 = Merchandised Transmission Auto Provisions (O/D)
If P84 is actually PB4, it would = Lock Control, Wheel.
If I remember correctly, E7Z = VSS delete
Old Aug 31, 2004 | 04:11 PM
gowman's Avatar
VSS Delete?? Pls clearify... Thanks
Old Aug 31, 2004 | 05:19 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Cars with the E7Z option had the VSS (Vehicle Speed Sensor) deleted from the transmission. Along with this RPO code you should also have E5Z & E9Z as well. Follow the link below and you will find more RPO codes for the GM vehicles.
http://search.netscape.com/ns/boomfr...eralspecs.html
Old Aug 31, 2004 | 06:26 PM
gowman's Avatar
[QUOTE]Originally posted by Trickster
[B]Cars with the E7Z option had the VSS (Vehicle Speed Sensor) deleted from the transmission. Along with this RPO code you should also have E5Z & E9Z as well. Follow the link below and you will find more RPO codes for the GM vehicles.
Thanks for the information. Any idea what VSS did and what was the differance when it was deleted???
Old Aug 31, 2004 | 06:27 PM
CaysE's Avatar
I've researched the MX0/MXO code as much as I could on the Internet and through a couple friends at various dealerships, and there are basically no clear answers to it. I know for a fact that I have MX0 (zero) and not the letter O, and I have reason to believe that MX* codes all end in a number. For what it's worth, the below is what I've concluded; there are possibly two RPOs. Mind you, I could be wrong and there is only one, but this is what I have:
MXO (this is the letter "oh") : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
MX0 (this is a zero) : MERCHANDISING OPTION ONLY-DO NOT CATALOG
This is not the actual RPO describing the trans in the car; MD8 is the 700-R4 automatic trans RPO. If you have a different RPO starting with M, that would be your trans, but you may want to double-check M0D. I don't think that is right.
Old Aug 31, 2004 | 11:16 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
E7Z - KEY, SPEEDOMETER (DELETE)
MX0 - MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
M0D - ????
P84 (PB4) - LOCK CONTROL, WHEEL
UUB - AM/FM Stereo System, Delco-Bose
1HV - COMPONENTS OF WS4 TRANS AM OPTION(PONT) or COMPONENTS OF IROC-Z PERFORMANCE PKG(CHEV)
Old Aug 31, 2004 | 11:32 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Firebird90,
I think if you would check again, you will find that what you have listed for RPO code E7Z is actually RPO code E9Z. There were 3 codes in this group.
E5Z= Speedo Adapter (delete)
E7Z= Vehicle Speed Sensor (VSS) (delete)
E9Z= Speedometer Key (delete)
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
