4th gen console problem please help me
Old Sep 11, 2004 | 04:35 PM
whitebird312's Avatar
Car: 90 trans am
Engine: 5.7
Transmission: auto
im kinda slow at doing this swap but i using an auto console and haveing problem with shifter do i need forth gen shifter or what the shifter plate wont fit in i moved shifter every way i can do you have to cut ashtray out or what please help me i need your expertise thanks
Old Sep 11, 2004 | 06:54 PM
Aredross's Avatar
Car: 1990 RS coupe
Engine: TBI 305.
you have to move the shifter over to use an automatic 4th gen console someone else will be along in a minute to tell you how to do it or tell you to do a search
Old Sep 11, 2004 | 08:10 PM
subliminal's Avatar
Using the manual 4th gen console on an auto is alot easier.
Old Sep 14, 2004 | 08:01 AM
wlsmoku's Avatar
Car: 1988 GTA
you have to move the shifter back about 2-3 inches. use a BFH on the rear bracket to bent it flat, and slide it back as far as you can, then drill new holes. I also had to take the drive indicator plate out to get mine to fit too. As stated about the manual plate is the easiest to get to work, but who said modding is supposed to be easy
Casey Meyers
Mar 2, 2016 10:46 AM
Omega
Oct 1, 2015 02:20 PM
sreZ28
Aug 14, 2015 07:48 PM
TheJoeY88
Aug 13, 2015 06:51 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
