Rust, the everlasting problem
Old Sep 24, 2004 | 05:39 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
I have some rust issues, and some big ones too. the strut inside the hood, where the shocks are, is rusting out around the bottom. and i heard it's a pain, and a ton of money to have it fixed, that true? and also, does rust constantly keep going or no? here's my thinking, rust=ironoxide...iron+oxygen=ironoxide, you need iron/steel and oxygen to get in there to cause rust, like water. salt is what starts the process because it can break into the metal.is if the rust you already have is never exposed to any more water, then the rust shouldn't grow any more, am i right? cause i really don't wanna have to repair this, unless i have to. any help?
Old Sep 24, 2004 | 07:41 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
POR-15 // Naval Jelly // Rust Converter
Look into these products.... its not like any of them are that big a deal to use, not like cutting out the rust and having to weld in new metal or anything. Cuz i mean, good luck keeping moisture away from the rust you already have, thats a pipe dream. So your best bet would be to do something about it, but that doesn't mean it needs to be a giant project.
edit: that's assuming you don't have any giant holes or anything in integral parts of the car.
Old Sep 25, 2004 | 09:28 AM
Car: '94 Z28
Engine: LT1 350
ok, but will rust keep growing even if i don't get any water on it, like not a drop? or does it need water to grow?
Old Sep 26, 2004 | 12:08 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
Im no scientist, but i believe it does need water.... but barely any... so good luck keeping condensation and other unavoidable liquid encounters away from it.
Old Jul 24, 2005 | 11:11 PM
85and87's Avatar
Car: 85 and 87 trans am
Engine: 305 to be 383
the water in the air is enough to do it over time.
Old Jul 25, 2005 | 12:30 AM
VILeninDM's Avatar
You probably need to figure out exactly how much rust you have on there right now. Rust converter will convert the rust on the top to the black stuff, but if the rust goes in deep, it won't get to it. The thing about rust is that it is really like a cancer. Unless you get rid of it completely, it will keep coming back.
There was a member on here whose strut towers got so weak, one of the struts pushed right through it. That's scarry.
I just spent 5 hours wire wheeling the same areas on my car right down the metal. Mine looked scarry but once I started doing it, most of that stuff was only on the outside. But you'd never know it unless you go through this process. Once you do that, use rust converter (aka metal conditioner) to make sure whatever is left in the pits is treated and then recoat it with something durable. Some people like por-15, I am going with Zero Rust.
hectre13
Sep 8, 2015 03:38 PM
hemicudakidd
Aug 31, 2015 06:23 AM
neekolzun
Aug 24, 2015 04:59 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
