Coupe v. Vert interior
Old Oct 15, 2004 | 05:36 PM
NCGiant's Avatar
Car: 1990 Iroc-z convertible
Engine: 305 TPI LB9
Transmission: 700 R4
I have a 90 vert and want to put new seats in. I have found some in the classified ads, but im unsure if they will fit. Did the coupes have the same dimension seats as the vert. In other words, will the rear seats fit under the plastic of the tanneau(sp?)
Old Oct 15, 2004 | 11:32 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The F-body coupe and convertible rear seats are the same. Just make sure that if yours has a split-rear seat back that you are buying a rear seat with the same split rear back. You can swap a non-split rear seat back in place of a split rear seat back, but that involves modifying your car by cutting off the inner hinge posts from the driveshaft tunnel.
The only rear thirdgen seat that may have a problem in your convertible would be those from a 1988 Firebird GTA notchback or 1989 Turbo-Trans Am (due to the headrest). But due to the rarity of both of those models, you'll likely not find those rear seats anyway (and would pay through the nose if you did).
Lon
Old Oct 16, 2004 | 08:32 PM
NCGiant's Avatar
Engine: 305 TPI LB9
Thanks for the info, you saved me.
1992Z28!
Nov 19, 2015 07:33 AM
topduarte
Nov 12, 2001 08:07 PM
topduarte
Nov 8, 2001 08:27 PM
nikh23
Car Audio
Aug 30, 2001 05:50 PM
nikh23
Aug 29, 2001 08:58 AM
