Does autozone or any other rent a tool service carry a door spring compressor?
Old Oct 25, 2004 | 04:54 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Just recieved my new lower hinge pins and bushings and want to put these on asap. Any of these stores carry it?
Old Oct 25, 2004 | 05:51 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The tool the dealer uses is a long crow bar looking thing that probably has tongs to hold the spring while it compresses.
I had to take mine to the dealer since I played for an hour or so trying to get my spring installed. Took the tech about 5 seconds to install the spring. I was about 30 feet from the car when he did it so I couldn't see exactly what the tool looked like.
Old Oct 25, 2004 | 07:39 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
When I did my pins I couldnt find the tool anywhere. I ordered one from Lon @ TDS.
Old Oct 25, 2004 | 09:25 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
i know this isnt the best way but i used a solid elec. wire and a pair of vice grips to install them. mashed the spring in a vice, twisted wire tight, put it in, then cut wire and it popped in. didnt want to spend money on a tool that would never be used again.
Old Oct 25, 2004 | 10:34 PM
sellmanb's Avatar
Car: '86 Berlinetta
hooga said exactly what i have seen done. Take some metal wire (that will hold, like piano wire). Wire it through the middle of the spring, then tie it from the outside and keep tying till it compresses. Then take it out, and do the same for the new spring, and put it in then cut it with wire cutters.
Old Oct 26, 2004 | 08:06 PM
aerosmithr0cker's Avatar
Car: 1991 Z28 clone & 1985 Fiero 2M4
Engine: 305 TPI (In Progress, Camaro) & 2.5L 4 cyl soon to be 3.4
Transmission: 700R4 (Camaro) & Isuzu 5 speed (Fiero)
this is a parts site for a fiero but he sells a door spring compressor that works for any car.
http://rodneydickman.com/retail.html
Go there then click the tools tab, and it is on the bottom right list of tools. Its 17 dollars plus 5 dollars shipping but id say it is a hell of a lot safer than using damn wire to do it.
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 25, 2015 07:34 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
