Cervinis cowl hood showed up today!
Old Oct 29, 2004 | 04:20 PM
Rage13's Avatar
Car: 89 Firebird
YAY! Took the day off work cause I had to be here to sign for it and had some time to put it on too. Still have to work on fitting it a little tho.
Old Oct 29, 2004 | 04:25 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Looks good man,paint that thing aand it will be really sweet.
Old Oct 29, 2004 | 07:06 PM
Rage13's Avatar
Car: 89 Firebird
thanks, but paint isn't going to be coming for a little while tho.. still need new doors and a Trans Am Aerowing Spoiler, but after that its getting a metallic blue that dodge is using(2004 color) for the body and silver on the ground-fx. should look real nice when its done
i'm having a little trouble trying to get the hood to sit down just right. the driver side is sitting up to high along the whole side and the passenger side is sitting up to high but just near the front, but the middle of the hood sitting at the right hight.. i've turned those 2 rubber stops all the way down and pulled out the 4 rubber triangle things along the fenders but still don't sit right.. so what did i miss?
Old Oct 29, 2004 | 07:16 PM
Rage13's Avatar
Car: 89 Firebird
passenger side
Old Oct 29, 2004 | 07:17 PM
Rage13's Avatar
Car: 89 Firebird
driver side
Old Oct 29, 2004 | 08:00 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
How do you go about fitting something like that? Sucks that it doesn't fit right to begin with.
Old Oct 29, 2004 | 08:10 PM
nick418's Avatar
Engine: L98, Hemi 6.2
hood looks great!
Old Oct 29, 2004 | 11:32 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
did u adjust any of the rubber adjuster ***** in the front? if not mess with them a bit. also check make sure the little rubber piece that sit on where the fender bolts to arnt hold that back. if so u may need to trim where they hit or adjust ur fender/hood gap. my brother has 2 of those hoods and the both fitted really good . one need slight trimming and then other didnt, but the hood is great quality, best one out there.
Old Oct 30, 2004 | 12:06 AM
1 BAD AZZ Z-28's Avatar
Car: 1987 Z-28
Engine: YOU WISH !!! COME RACE ME AND FIND OUT !!!
Transmission: YOU WISH !!! COME RACE ME AND FIND OUT !!!
Hi RAGE13.Hood looks good, but It'll be tight when its painted . I was just wondering if that is the stock nosepiece on your car?If not, where did you get it?it just looks like to me that its a little sharper angle or protruding a little bit more?Maybe I just need to get my eyes checked LOL.
Old Oct 30, 2004 | 12:08 AM
Rage13's Avatar
Car: 89 Firebird
hood is great quality, just going to need a little tweeking like most after market stuff. rubber ***** are all the way down and the rubber parts on the fenders are out of the car right now.. i'm going to mess with it a little more tomarrow and if i can't get it figured out i'll just take it by my body shop and have them take a look at it
Old Oct 30, 2004 | 12:11 AM
Rage13's Avatar
Car: 89 Firebird
its the stock 82-84 nose, its alittle bit pointier then the 85-92
you can have it if ya want, i've got a set of 89 bumpers and ground-fx getting ready to go on soon
Old Oct 30, 2004 | 02:01 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
nice hoods, great quality
Old Oct 30, 2004 | 08:10 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Should look great when done.
but why a red roll bar if your doing the car Blue
Old Oct 30, 2004 | 08:22 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Just wondering here, but if everything else checks out ok, I'd wonder if the car hasn't been in an accident of some sort. I've never seen a Cervini THAT far off before.
Old Oct 30, 2004 | 08:24 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
The fit on these hoods are the best you will ever find with any aftermarket hood, period.
I would lower the hood closure point, as it looks a little high on both sides. Hope this helps!
Old Oct 30, 2004 | 09:37 AM
LUVmy92's Avatar
Car: Camaro
I had to remove the rubber peices from the fenders to get mine to sit completely flush with the fenders due to the design difference from the factory hood. Mine basicaly bolted right on with very minor adjustmentsbeing needed. I think it took about 1 hour to get it perfect.
It will be awesome once you paint it!
Old Oct 30, 2004 | 06:02 PM
Rage13's Avatar
Car: 89 Firebird
roll bar will be the same color blue as the body when done, only used red because thats the only paint i had enough of to do it all in one color
Old Oct 30, 2004 | 06:26 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I thought maybe you were gona go a red and changed your mind to blue...
Thats why I did my CE 8point in a metalic grey. to match the 4thGen dash and Int. Because I cant make up my mind on black again or HOk cobolt blue
Old Oct 31, 2004 | 10:06 AM
V6camaroman's Avatar
hood looks great man. thats a 3" right? im still deciding on a 3 or 4" for my 85z. yours looks good though. what was the price? car looks nice as well. i like the black on gold
Old Oct 31, 2004 | 11:29 AM
Rage13's Avatar
Car: 89 Firebird
its a 3", after driving it around yesterday i wouldn't want anything higher. but thats just me.. the price was $400 for the hood and $100 shiping to south florida (shiping should be less for you sence Cervinis is in NJ, if you go with them)
i've always loved the black on gold camaros, but hate having a black car.. shows every little spot and bump (witch there are alot of ) and no a/c makes it cook better then an EZ-Bake oven. but i still wouldn't trade it in for anything
Old Oct 31, 2004 | 11:37 AM
Rage13's Avatar
Car: 89 Firebird
grabed a few pics of the inside for ya
Old Oct 31, 2004 | 11:38 AM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
Awesome hood dude, how long did it take to come in? I'll be ordering mine soon..
Mike
Old Oct 31, 2004 | 09:17 PM
Spdfrk1990's Avatar
Wait your driving around with no dash?
Old Oct 31, 2004 | 10:18 PM
Rage13's Avatar
Car: 89 Firebird
that ain't the only thing missing
SnkSknrZ28: it took 4 days for it to get to me
Old Oct 31, 2004 | 10:34 PM
Spdfrk1990's Avatar
Did you notice a big difference from that cage.
Old Oct 31, 2004 | 10:43 PM
Rage13's Avatar
Car: 89 Firebird
oh yeah did the cage with cross brace and spohn sub-frames at the same time, and what a difference! body dosn't flex at all now.
Old Nov 1, 2004 | 06:09 AM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
thats soo sweet... i wish i had a car to gut like that and make a full drag car... that would be so sweet... what are your plans for the car tho? kus i think the red roll cage wiill go good with the blue... and give it a thick stripe down the middle and youll have a 3rd gen Grand Sport... lol like the corvette grand sport of course....
Old Nov 1, 2004 | 09:06 AM
iroc87matt's Avatar
Car: 87 GMC Sierra
Transmission: auto
my uncle got a hood from cervini's and he had the same problem. he did some shaving on the sides and did a few other things and it sits alot better now. car looks really good man, cant wait to see it when its done.
Old Nov 1, 2004 | 09:25 AM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
What do you have in there?
(I am assuming you didn't need that cage for a 305/700r4 combo under your name. )
Old Nov 1, 2004 | 05:55 PM
Rage13's Avatar
Car: 89 Firebird
IceManRS305, building the car for autocross/road racing. you can also gut your car and drive it everyday, i do. only car i own
iroc87matt, went by the body shop today and found that i need to lower the middle of the nose alittle bit, after i do that it should all line up right
ES87iroc, 305/700r4 is still there for now, but i'm 2/3 saved up for my LS1/T56 can't wait till thats in
Old Nov 1, 2004 | 06:46 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Nice hood rage. Definetly one of my favorites.
Old Nov 1, 2004 | 07:54 PM
BRILLIANTRED1's Avatar
Car: Brilliant Red metallic RS T-Tops &
Engine: 305 TBI & 350 LT-1(bolt on's)
Transmission: T-5 & 4l60
two words...hood latch....adjust that thing down ....had to do the same with my ram air II it should help
Old Nov 1, 2004 | 08:41 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
man, can't wait to get some cash saved up for my hood, wheels gotta come first though...
Street Lethal
Apr 30, 2019 12:14 PM
cougar20th
Aug 27, 2015 08:04 AM
LittleFranks
Aug 20, 2015 03:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
