Did all 3rd gens come wired for power seats?
Old Nov 4, 2004 | 02:41 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I recently picked up a set of power leather seats from a 4th gen and wanted to know if all late 3rd gens (87-92) were wired from the factory for power seats. They seem to be wired for everything else regardless of actual options so I thought I'd ask. If not then where could I tap in to make the connections for the power slider,lumbar and bolsters?
Old Nov 4, 2004 | 05:06 PM
paul russell's Avatar
Car: 86 trans am
Engine: 5.0 tpi gtauto ramair and notch
Transmission: 700 r4
when i did my seats i went to the dealer and orgered the harness so the two seats would plug in together then i just ran a 12 volt sourse froim the fuse block ( there is a open single blade terminal on mine ) it is all the time hot though dont bother me i fused it with a 20 amp. been almost a year and no issues
BTW the harness comes with the hoses that run the pumps and is a very clean setup. if i can did up the part number i will post it later on tonight
Old Nov 4, 2004 | 05:28 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
nope . . I recently installed pwr cowskins in my '91 and I could not locate the harness. The slits were cut into the carpet beneath the seat -- but alas no harness.
Old Nov 4, 2004 | 08:24 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
you run a constant hot (or ignition if you prefer) and then a ground to the seat track bolt, or somewhere close. i thought all cars came wired. i had power, so it was an easy plug in for my 02 TA seats.
Old Nov 4, 2004 | 08:57 PM
Mongoose's Avatar
Car: 90 Formula
I also have the complete harness for the seats,I was just hoping there was something there to plug it into from the car's end. No biggie though.
Old Nov 4, 2004 | 10:23 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
did the same thing paul russell did. no problems so far go for it.
Old Nov 4, 2004 | 10:34 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
dont forget to post pics
Old Apr 30, 2008 | 02:46 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: Did all 3rd gens come wired for power seats?
So what did you have to do to add your power seats
Old Apr 30, 2008 | 05:03 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
my 88 iroc did not have any wires for power seats. big disapointment!! my brother told me to just add a wire to the fuse box but i am not sure exactly what to do there. the set of seats i got only have a power drivers seat so i just need a good power source. any ideas?
Old Apr 30, 2008 | 08:37 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Yes there is an empty slot in the fuse block. Then just run a ground to one of the seatbolts.
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
