LCD mirror compass
Old Nov 6, 2004 | 11:32 AM
nosaint's Avatar
Car: 1986 Trans Am
LCD mirror compass
I just snagged one from the Junkyard and I need to know the exact procedure to calibrate it. This one has a LCD dispaly in lthe upper right corner and a little cylinder near the base with a button you press. When u hold it down the cal indicator comes on but it you hold it longer u get a 0 with a line and then a 0 with an x.
I know you have to drive around it a slow cirlce but if someone has this mirror with the instructions that would be great!!
Old Nov 6, 2004 | 02:51 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Which car did you pull this out of? I've been looking for a mirror like this.
Old Nov 8, 2004 | 08:16 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If this came off of a late model GM truck (which it sounds like it did judging by your compass calibration attempt), go to www.fullsizeschevy.com and do a search.
My father just retrofitted that mirror into his truck and had to do the calibration, but I don't remember the exact procedure. Doing a search on fullsizechevy.com should give you all the info you need though.
Old Nov 8, 2004 | 10:10 AM
nolanr0413's Avatar
Car: Trans am
when we had our 99 silverado we had to do it once. I think all we did was drive around in a circle a few times to calibrate it . Like in a parking lot . Just drive around in a circle or two .
Old Nov 8, 2004 | 12:10 PM
Jim85IROC's Avatar
one step of the procedure that I do remember is that you're supposed to do the circle at under 5mph.
Pac J
May 17, 2020 10:44 AM
1992Z28!
Nov 19, 2015 07:33 AM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
scottmoyer
Sep 7, 2015 07:06 PM
