My windows "puff out" at high speeds
Old Nov 10, 2004 | 01:07 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I'm guessing due to pressure being decreased outside of the cabin... Anyway, the window, moreso drivers side, sticks about 1/4" to 3/8" outward overlapping the weatherstrip when I am on the highway. It howls like crazy and sucks in coooold michigan air. What should I adjust first?
Old Nov 10, 2004 | 01:10 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
The window stops! Pull your door panel off and there two white (atleast on my car) stops at the top of the door just untighten them and adjust so the window sits tighter at the weatherstripping and then retighten.
Old Nov 10, 2004 | 01:11 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
i pulled the window stop out because i thought it might help, but it didn't. so technically the window is up as "high as it goes"
Old Nov 10, 2004 | 01:12 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
in fact it got worse without the window stop...
hmmm
Old Nov 10, 2004 | 03:21 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
What kind of shape are your external "window sweeps" in? These are the rubber strips along the top edge of the door that are felt backed and press against the window on the outside (they also have a metal component that helps keep the window from moving around so much). I know when I first got my '84 the windows did just what you descibe and the window sweeps had actually been removed by a previous owner (I'm assuming to perform the lousy paint job that's on the car). Once I installed a new set of these my windows did not "puff out" at speed (used to starting at about 45 mph) and were also noticibly more stiff when wiggled with the door open. This also lead to the windows not banging around so much when closing the doors. Just a thought, your problem could be something else, but I'd check into that. Good luck!
-Paul
Old Nov 10, 2004 | 07:33 PM
Car: 92 Z28
hmmm
Yes exactly!! The window stops dont just "stop" the window they keep it in place. So thus with no window stops your window is free to blow all over the place. Put them back in a adjust them appropriately and you should see a big difference. I dont think there is any way to completely get rid of the noise at really high speeds but that should help alot.
Old Nov 10, 2004 | 07:36 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
hmm good question i have this probelm on my 89 but not noticable till 100+ noticed it one night comin home from gratiot made it home in record time but was a lil noisy it hink mine is casue the t-top weatherstripping is clucked?
Old Nov 10, 2004 | 09:25 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
can i get a picture of the inside of the door?
1992 Trans Am
May 10, 2023 07:19 PM
bryan623
Mar 22, 2021 06:43 PM
colton_carlson
Mar 8, 2019 12:21 PM
RedLeader289
Jan 22, 2016 03:05 PM
Dialed_In
Aug 20, 2015 01:45 PM
