What should I use to reseal all the drain holes in the floorpan and seatbelt brackets
Old Nov 9, 2004 | 12:16 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I took out my carpet in the passenger area of the car and stripped the entire floor pan to bare metal to coat with POR-15. I removed all the covers for the drain/access? holes in the floorboards. 4 were originally covered with that sheet of tar? (#1 pic) or whatever and the other 2 under the back seats (#4 pic) were sealed with somekind of glue or whatever. What should I use to reseal them?
also where can I get those tar like seals they have under all the seatbelt brackets? (#3 pic) ThanX.
Attached Thumbnails What should I use to reseal all the drain holes in the floorpan and seatbelt brackets-floor.jpg
Old Nov 10, 2004 | 10:09 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
seam sealer
Old Nov 10, 2004 | 10:17 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
ThanX. I was thinkin that. Since I am replacing some of the seam sealer in the car anyway, but wasn't sure if it would hold the metal covers good or not seeing how fragile the stock seam sealer was. But hopefully the 3M stuff will last.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
L0tuS
Oct 4, 2015 08:07 AM
ericjon262
Sep 11, 2015 06:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
