question on 85 mph to 140 MPH speedometer swap
Old Nov 13, 2004 | 04:41 AM
85Blackbird's Avatar
Car: 85 firebird
Engine: 305 5.0 L carbbed
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7933398752
ok, so my 1985 v8 automatic firebird has the dreaded 85 mph cable driven speedo, and i wanna swap to this (seems to be rare) 140 cable driven speedo (rare cuz itz a cable driven 140).
but, it doesnt seem to match exactly what i have.
(sorry no pic).
my tachometer goes to 6000 and this one goes to 8000, while my tachometer goes all the way around, and this one stops at 2/3 way.
also, the locations of the oil, water, batery, and gas are different.
my third pod from the left has battery on top and OIL on the bottom (not gas as shown here), and 4th pod from the left (last one) has gas on top and water on the bottom).
to be more specific the gas and oil gauges are switched.
will, this 140 mph speedo and gauge cluster even fit in my car?
i've already taken out my cluster a few times with no problems so i know how to swap them, but if i replace it will my oil show the gas gauge and vice versa, or will it just WORK CORRECTLY?
this firebird gauge cluster is the only one on ebay i've seen that is cable driven like mine ..... i would prefer the 120 mph ones though.
plus, this ones pricey compared to others i've seen
Old Nov 13, 2004 | 04:53 AM
Car: 85 firebird
http://cgi.ebay.com/ebaymotors/ws/eB...934440482&rd=1
aha, here is what mine looks like...
note the diferent tach and oil and gas are in oppsoite locations
Old Nov 13, 2004 | 09:44 AM
87and 93birds's Avatar
Car: 87bird and 93 formula
Engine: 305 and 350
Transmission: auto
thats a km/hour set not miles an hour . look close and you can see.
Old Nov 13, 2004 | 12:24 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Bingo. Looks exactly like to one from my 86 'bird. Our Canadian ones had the km/h on the outside and the mph inside. It's exactly the same as what you have.
Old Nov 13, 2004 | 12:33 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
so will these hook up in early 3rd gen firebirds? I'm interested as well. How will the gauges work since they are opposite to the originals?
Old Nov 13, 2004 | 02:33 PM
Car: 85 firebird
oh, and it turns out to be elctric too.
hmmm, well im definately not getting that one then.
but i saw a few others on ebay i might just be able to get... but same problem.. oil and gas gauges are switched.
Old Nov 13, 2004 | 04:07 PM
If you get an 85-newer cluster, you'll need to 're-pin' the wiring at the connectors.
An 85 cluster would be the easiest overall swap, as it is still cable-driven. The 86 and 87 clusters <i>with gauges</i> and the 88-up were all electrically driven; the 86 and 87 ones <i>without</i> gauges still used a cable.
If you decide to upgrade to the electric unit, this will help you http://www.hioutput.com/tech/speedo.html
Old Nov 14, 2004 | 02:23 AM
Car: 85 firebird
thanx pete, i had already seen that page, i just didnt want all that time and trouble yet. (convert cable to electric)
but, i dont think there will be another choice as i dont think 1985 came with anything other than 85 mph gauges.
well, originally i wanted to just get, white face glow gauges, or reverse glow, but they are only in 120 mph and 145 mph.
i already tried replacing the bulbs with blue bulbs, and a light blue electric wire, looks, good, but not good enough.
instead i think i'll replace the blue bulbs, with super bright leds (4 per bulb) and maybe even design my own white gauges using photoshop and reflective matte paper.
when i do, i'll post a DIY and the final gauges for everyone to use.
Frozer!!!
Jan 19, 2024 04:55 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
ChevyZ71
Aug 13, 2015 07:30 AM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
