house of kolor time!!
Old Nov 24, 2004 | 10:15 AM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
the time has finally come i am repainting my car with all house of kolor products!!
last night i applied the KP2CF primer and friday i will commence the rest of the paint
here is the combination:
kandy teal with fushica mini metal flake flames on the nose extending into the hood
the flames will then be outlined in a slime green color
oh by the way the car is a 1992 camaro RS
Old Nov 24, 2004 | 12:14 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
hok products are great to use... i used them on my project love how it sprays. are you wet sanding the primer before the base ?
Old Nov 24, 2004 | 12:17 PM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
yes i will be wet sanding it tomorrow and then doing the top coats on fri morning. i have to wait a week approx to lay down the flames. they say 24 hours but i just want to be safe. its fall time here in PA so its not liek i can drive the car right now anyway
Old Nov 24, 2004 | 12:44 PM
JeffW's Avatar
Engine: 305 tpi LB9
you should use an innercoat clear they sell. you do the base then let it set up and then the inter coat clear then you can safely tape and do you flames then clear after that. i think the tech manual even states to use it for taping directly over the base so you don;t get lift of the base. better check your sheets before you start. i also think there is a window for clear if you wait more than 24 hours you need to scuff the base reshoot and then clear with in the window. but i could be wrong been like 10 months since i last painted.
kp2c is that the metalic one?
just in case
good luck and post pics
jeff
Old Nov 24, 2004 | 08:45 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
yep I finally got to see some of my hok kandy apple red go on my car yesterday!!! Just the door jambs, but after waiting four long months, just the sight of the red had me drooling over what the rest of the car will look like soon enough
Old Nov 25, 2004 | 08:33 AM
JeffW's Avatar
Engine: 305 tpi LB9
well it looks like we will have a few candy cars here i have candy coabalt blue. post pics when its done.
Old Nov 25, 2004 | 04:18 PM
yea I love the pics of it on your car too! I had a chance to see it on a impala and it looked awesome in person (candy really doesnt do justice in pics). I was considering that color, but since my car was maroon before I figured I'd stick with something red....pics soon enough I hope
Old Nov 25, 2004 | 05:00 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Jeff is right, tape time is usually 30-40 minutes. If you wait more than 24 hours, you'll have to scuff the basecoat and reapply.
Old Nov 25, 2004 | 06:20 PM
JeffW's Avatar
Engine: 305 tpi LB9
kandy is real nice just hard as hell to spray.. and once you goof its back to the sand paper. i found a trick of swapping spray gun head direction from side to side to up and down between each coats helps it be nice n even if your a amature painter like me...
my car was blue so it stayed in the same area.. there are some real nice candy reds out there. see the new vette wow that has a candy red color on it and man does it pop. i think it was close to the color of Kandie91z car. real sweet.
jeff
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
db057
Aug 22, 2015 08:17 PM
perZ
Aug 15, 2015 01:17 PM
