Firebird nose cone swap
Old Dec 1, 2004 | 10:31 PM
383T/A's Avatar
Car: 84-88 Pontaic Trans Am Convertable, 88 S-10 350, 89 S10 2.5L
Engine: 383 - 475 hp 485 ft lbs
Transmission: WC T5
Axle/Gears: 9 Bolt
Hey
I have a '85 transam convertable its mint except the nose cone is cracked.
I have one available from a forumla i believe it looks like the one in the pic
Will this just bolt on like one from another transam?
Old Dec 1, 2004 | 10:33 PM
383T/A's Avatar
Transmission: WC T5
Axle/Gears: 9 Bolt
Old Dec 2, 2004 | 12:34 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
Yes,you can do it!!!!!!
All you will need to do is just swap out the impact steel plate and just about everything that attaches to the bumper and the turn signals should be easy to move around too!
Old Dec 2, 2004 | 03:58 PM
383T/A's Avatar
Transmission: WC T5
Axle/Gears: 9 Bolt
sounds good, so the ground effects on the fenders will line up with the nose cone?
thanks
Old Dec 2, 2004 | 04:38 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
is urs a 2 seater? or a conversion convertible since they didn't offer a factory vert. on the t/a in 85...just curious if it's one of the ones done out of house as a dealer option.
Old Dec 2, 2004 | 06:05 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
No the Trans AM ground effects do not line up w/ the base model/Formula nose.
Edit: You're sayin you have a 91/92 Formula nose? I'm not 100% sure about that, but if you have an 85-90 formula nose, you'll have holes in your fenders because you have to remove the GFX.
Old Dec 2, 2004 | 09:36 PM
383T/A's Avatar
Transmission: WC T5
Axle/Gears: 9 Bolt
yeah the formula that I was looking at in the wrecking yard appered to be a base model because it dident have ground effects.
Are all the formula nose cones the same?
Do I have any other options here? Its going to look pretty funny without gfx on the fenders but gfx everywhere else. Can I trim the gfx on the fenders or do they just not line up at all.
Any info is apprecated
85f-bird
Yeah it it was origionally a coupe but it was converted in a shop where they welded basically a frame underneath the car connecting connecting the subframes and bars running from back wheel to front wheel. Overall it is quite rigid
Old Dec 2, 2004 | 11:06 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
There were two different types of 91-92 bumper covers. The one in the picture looks like a Trans Am type while the Formula type has no foglights or GFX.
It would be better off if you found one off a T/A or base Firebird with Sport Appearance Package and the fender GFX pieces that go along with it.
Like this one. :hail:
Old Dec 3, 2004 | 12:21 AM
383T/A's Avatar
Transmission: WC T5
Axle/Gears: 9 Bolt
O.k so the base firebird and the t/a with the sport apperence packages both would have the same gfx and nose cone?
How common are these as in what are the odds of finding one in the wrecking yard?
thanks
Old Dec 3, 2004 | 12:30 AM
383T/A's Avatar
Transmission: WC T5
Axle/Gears: 9 Bolt
B]How about this nose cone is this a t/a with the sport apperence package?[/B]
On the sport apperence package ta would all the gfx be different? hight, width and styling so it would look funny with just the fender gfx from the sport apperence ta....
Dose anyone make an affordable aftermarket nose cone?
Old Dec 3, 2004 | 02:56 AM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
You're also gonna have to grind off the lip on the headlight bezel to get the lights to close with the 91-92 nose.
Old Dec 3, 2004 | 10:26 AM
89V6FBIRD's Avatar
I'm sure it would be easier to find an 85-90 Trans Am, 87-90 GTA, or 85-90 Firebird w/ the ground effects (aka sport appearance package).
Mine is a base model 'bird w/ the package (pretty much a V6 bird w/ the T/A GFX)
Old Dec 3, 2004 | 11:18 AM
Morley's Avatar
Your nose piece should have 5 studs in it to hook to the fender..correct?
The 91/92 "Banshee" nose only has 4, so there is another stumbling block.
You can make any 3rdgen part fit any year 3rd gen...but sometimes it takes way more work than it is worth or you want to put into it.
Old Dec 3, 2004 | 04:18 PM
'82 Beater's Avatar
If you don't need that 91-92 base model nose, you should buy it from the junkyard anyway and sell it on eBay. They only made those for the two years, new GM ones are like $600 and they sell used for about $200-300 on eBay.
xkingcodex
Feb 12, 2020 07:43 PM
masonta
Aug 31, 2015 10:14 PM
E Rod
Aug 28, 2015 05:17 AM
neekolzun
Aug 24, 2015 04:59 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
