Got into a accident...
Old Dec 5, 2004 | 01:52 PM
91RSHawaii's Avatar
Car: 1999 30th Anniversary Pontiac T/A
Ok, feeling pretty crappy right now, but here's what happened..
was taking a left turn, rainy weather, shifted into second, my tires i think went into a puddle, and I spunout, fishtailed into a stopped oncoming car, and did a 360...
Damaged my front clip, dented hood, and trashed the quarter panel. no damage to anything significant though...
So, what would I have to do to fix all of this? I know im going to need a new IROC/Z28 hood, a drivers side fender, a front clip, and a new front gfx.... Ive tried searching for a tutorial on removal and installation of these things, and have only come across one for removal of the driver side quarter panel, and was wondering if any of you guys could help me out with some directions. Thanks!
Old Dec 5, 2004 | 02:00 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
its all pretty straight forward. Just look for the bolts and unscrew them. Bummer about the quarter panel. That will probably have to get pulled. How bad is it? Hvae any pics? Good luck man. Just be glad you are ok.
Old Dec 5, 2004 | 02:05 PM
VILeninDM's Avatar
Before you do anything take it to a collision shop at least to get an estimate (that part is free). While there make sure they check the frame. Things may look like bent and replacable body panels, but you never know if the frame got damaged under that cosmetic stuff.
Old Dec 5, 2004 | 02:17 PM
91RSHawaii's Avatar
Turns out the modded accord I hit was past the white line at the intersection, so it's a no fault accident.. but the quarter panel is shot, as is the front clip, gfx, and the hood. ill get some pics up soon... any more suggestions? I'll be sure to take to a collision repair shop for the estimate/
Old Dec 5, 2004 | 03:27 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
good to hear, get it fixed at a shop
Old Dec 5, 2004 | 03:38 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
sorry to hear of the issues, but least it wasn't major and no one was hurt...good luck with everything, from end removal is pretty simple, all bolts, just take em out, haynes might have something on it, but i haven't checked recently...good luck.
ps-
it's a front fender, the 1/4 panel is on the back of hte car, if you had damaged that, you'd be looking at some $$ or you'd need a tad bit of cut/welding skills.
Old Dec 6, 2004 | 12:50 AM
91RSHawaii's Avatar
Oh yeah, what parts of the car should I look at myself to see if there is any major structural damage? The car still drives straight, feels the same, just looks like crap... Damaged cars are never the same though... just wanted to know how to ascertain the extent of the damage w/o some terror quote from a body shop.
Old Dec 6, 2004 | 03:44 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
as far as the removal of the front clip if you turbo ratchet i got off the bumper cover/spoiler/headlight unit/ theres 5 or 6 bolts inside the fender going horizontally some are hidden, a few upfront for the headlight panel, and some slipjoint pliers to remove those push studs, and your all done and the fender is only those bolts ontop/bumbercoverbolts and 2 hidden behind the gfx
all the bumper bolts are 10mm...youll need alot of extensions and swivel to ge tin there its pretty straightforward, and easy, go to a junk yard and practice pulling there if you feel like it thats what i do all the time i dont know how to do something i pay 2 dollars to get it and practice repairing/removing things if you really need i can scan you diagrams for bolt locatations but its very simple as far as the rear quarter goes thats gonna have to be cut and weld a new piece on..
Old Dec 6, 2004 | 07:54 PM
91RSHawaii's Avatar
oh the rear is fine, i mis-wrote quarter panel, when i met drivers side fender.
Old Dec 6, 2004 | 08:43 PM
OutLaw305's Avatar
That makes it a whole new ball game! Doesnt sound so bleak anymore.
Old Feb 1, 2011 | 12:17 AM
ericg83z28's Avatar
Re: Got into a accident...
that cost me 4800 with the new hood from harwood , a bit of structual damage
plasmeh
Apr 15, 2009 07:38 AM
tpi-hearse
Nov 14, 2006 11:09 AM
Stingraye
Jul 24, 2003 11:25 PM
GarageToys
Classified Ads Feedback Board
Feb 14, 2003 01:36 PM
383 Smoka
Jan 20, 2003 02:05 AM
