Need window inner and outter window felt for a 91'Camaro
Old Dec 16, 2004 | 09:34 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I was looking through Year One's catalog for new window felt and all I could find was the outter and the front triangle filler piece. Is an Inner available somewhere?? I want a whole kit. Inner, Outter and Filler pieces.....anyone know where I could find a good price??
Old Dec 17, 2004 | 05:42 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Old Dec 17, 2004 | 05:54 PM
1quikformula's Avatar
Car: 1991 Pontiac Formula
Engine: 350 C.I
Transmission: 700R-4
You can try here http://www.hawksthirdgenparts.com/in...?v=1&pid=18969
they also have all the other pieces if you look around, but i don't know if they offer a kit.
Old Dec 17, 2004 | 07:32 PM
Morley's Avatar
The "inners" are part of the upper plastic piece of the door panel.
Old Dec 18, 2004 | 09:39 AM
Engine: 350 C.I
Yeah it looks to be a one piece deal. If you take yours off and look at how the "inner felt strip" is mounted you'll see why it's a one piece.
Old Dec 18, 2004 | 10:21 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The inners are still available and like everybody has said they are part of the black peice of plastic above the door panel. They cost a bundle too. They list out at about $165 each at your local GM dealer! Wholesale would be right around $115 if your partsman will give you that pricing.
Part numbers are 20350900 and 20350901.
Don't know why Hawks 3rd-gen Parts says they are discontinued? Maybe trying to push a few more of the aftermarket units ....
Old Dec 19, 2004 | 11:41 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Inners are connected to the black piece but it's not like they couldn't be removed. Yes I can get parts wholesale but thats still a lot especially when all I need is the felt not the whole assembly. Besides that I would have an easier time trying to replace the felt piece vs. the whole assembly. If I remember correctly the black piece is stapled to the door panel and the felt piece just has push on washers over plastic studs that hold it in place
Old Dec 19, 2004 | 11:49 AM
Morley's Avatar
Backwards. The upper plastic piece is held to the door panel by 6 or 7 plastic studs with stamped nuts on it, inverted. The felt is held on by staples and a few plastic studs that have the ends melted to form a "head' to hold the felt.
Old Dec 19, 2004 | 04:06 PM
Dens71TA's Avatar
I gave you the wrong part numbers. The correct part numbers are 12394510 and 12394511. The ones above are for the door weatherstrip.
Looks like they may have just been discontinued. The part number isn't showing up good anymore although it did a couple months ago.
You may want to check with Metro, Steele Rubber, or Softseal and see if they offer the inner seal separately. It looks like you could use low profile head screws to attach it.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
BurlyChev
Aug 16, 2015 09:08 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
