How to fix metal flake runs
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
how do i fix metal flake runs?? ive heard that you cant sand it because the flake is actually silver and once you touch it it becomes silver and it looks horrible???
thanks
joe
thanks
joe
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
need more info....
is it a run in the base coat of a bc/cc finish or is it a single stage paint job.
jeff
jeff
Car: 85z28,
How bad of a run is it? I did a truck once in gun metal. I did not have any runs but it was dry. I wet sanded it lightly and it came out ok. A chevelle i did in the same color i hd a run in it and tried to wet sand it out. Were the run is its smooth but there is a dark line. This ws with single stage paint. With base coat clear coat u can wet sand the run out.But be carefull that u don't go through the clear coat.
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 11, 2015 10:11 PM
