Help on panel removal
Old Dec 30, 2004 | 11:38 AM
badCHEVELLEman's Avatar
Car: chevelle + camaro
Engine: 520hp 350 350
Transmission: th 350 700r4
Axle/Gears: 4:56 3:23
dont know if this is the right spot for this but it should still work.
the question is how do i take the panel off below the steering column or even better how do i drop the steering column i need to drop it because i suspect theres a reason my car wont start in there any help would be much appreciated
Old Dec 30, 2004 | 04:17 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If you're looking at getting to the steering column and start switch, there's a tech article here on tightening your tilt steering column that will walk you through it.
Old Dec 31, 2004 | 12:53 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
it depends on the year of the car and if it is a camaro or firebird. same setup tho. on the 82?-89 Camaro's there are 6-8 7mm screws holding the cover in place under the dash. then there are 2 phillips? screws holding the panel under the column. You should then be able to see the 2 large nuts holding the column in place (it has been a while since I had either of my 87's apart, but it is close to that)
On the 90-92 Camaro's, there are the screws under the dash as well, take that panel out. Then there are 2 round plugs in the piece just under the steering wheel on the dash. you have to take these out, but be careful not to destroy them or the dash. behind them are 2 bolts, and there are some at the bottom of this panel as well, holding the panel to the dash. When that is done, same as the older ones.....2 large nuts holding column in place
( I just un-installed a steering column in like 1.5 mins of reading time....will take longer in real life)
Old Dec 31, 2004 | 12:52 PM
is this really that easy or is there more to it the car is a 91
Old Dec 31, 2004 | 05:32 PM
82knightrider's Avatar
Transmission: TH200C....700R4
I just took that off to splice the passanger side floor light to the drivers side floor light ,its simple,just 3 screws should hold that piece on
Old Jan 1, 2005 | 01:06 AM
911rsq's Avatar
Transmission: yes
It's really that easy...take those covers off on the front of the panel and you are set. It is really straight forward when you get into it. 7mm and 10mm should be all you need to remove the panel.....(i think)
Old Jan 3, 2005 | 07:08 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
torx head screws
I just remove my lower panel today. Mine is a 92. They were #30 torx screws I think. The two plugs you have to take out had me stumped for a while. They aren't too easy to remove without ruining them. I finally used a box knife blade to get them started out and finished with a thin flat screwdriver. I haven't removed the steering column though.
Old Jan 7, 2005 | 07:28 PM
pondriver do you think you can walk me though what exactly what has to be done and any complications are involved much appreciated thank you
Eric
Vintageracer
Jan 10, 2020 05:33 PM
tcflint
Sep 14, 2015 04:55 AM
Street Lethal
Aug 14, 2015 08:25 PM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
