4th gen door panel teaser..
Old May 18, 2006 | 02:37 PM
  #51
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Hey Shroom,
Any chance of getting some more detailed pics pf the door panels? I'm woerking on mine now, and just wondeering how far foward on the door yours are, and how much metal is left at the bottom of the door? Thanks
Old May 18, 2006 | 07:53 PM
  #52
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Nope, sorry. It would take a lot of work to get more pics of them right now. They're forward enough that the stock kick panels and lower a-pillar plastic won't work to well. I'm using the 4th gen stuff for that to solve the problem.
Kevin D.
Old Aug 6, 2006 | 09:36 PM
  #53
ReidK's Avatar
Car: 1988 Firebird Formula t-tops
Engine: 350 60 over...400 HP
Transmission: 700 r4 transgo shift kit
Axle/Gears: stock...373?
I'm working on my door panel now...what would be the best way to modify the front of the panel where the a-pillars get in the way, without getting the 4th gen ones?
Old Aug 6, 2006 | 10:04 PM
  #54
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
Reid, for your original post, the key to the handles seems to be getting the panel on where you want it first. then simply drill a hole to screw the trim piece on to, then measure back from that hole to the rivet that holds the handle on ...]
Old Aug 6, 2006 | 11:43 PM
  #55
shr00m's Avatar
I originally had just cut it down and trimmed it with door guard. To fill the hole I used some fabric covered foam. Now that most everything is going to wrapped in leather/vinyl I'm just fiberglassing it to what fits.
Kevin D.
Old Aug 7, 2006 | 07:15 PM
  #56
ReidK's Avatar
another question...there is like a ridge along the top of the door...in one pic you have some of that ridge thing pounded down flush with the door...do you pound that thing down all along the top of the door, or just the back 2?
Old Aug 7, 2006 | 09:16 PM
  #57
shr00m's Avatar
Mainly just the back half of the door. I also had to cut some down the side to help it sit right.
Kevin D.
Old Aug 7, 2006 | 09:32 PM
  #58
ReidK's Avatar
how do you get the bottom of the panel to go down further without nocking them ridges down? My panel shows alot of metal at the bottom of the door. Can you give me the measurements on where to cut down in the back.
another thing when my door shuts the bottom of it hits the seat belt retractor that's on the floor. Because it has a compartment for change or maps or whatever on the bottom of the panel. How do you get around that?
Old Aug 7, 2006 | 09:46 PM
  #59
shr00m's Avatar
Umm... That's why you have to knock the ridges down..
Nope, just cut of what hits.
I'm not using the stock seatbelts. Putting the panel on like I am, so that it looks decent everywhere, interferes with A LOT of stock stuff. It's not simple or quick and you will be chasing problems around until everything works out.
To quote myself from one of the first replies, and something you should take to heart:
To get it to fit with no gap you have to make a commitment that you are going to make them work. If you go in trying to keep everything for the 3rd gen panels to still work, they'll never look stock.
Kevin D.
Old Aug 7, 2006 | 10:34 PM
  #60
ReidK's Avatar
i took that to heart...umm about the ridges...i meant how do you get it to fit without nocking the front ones down? i have the back ones down but the panel is still showing quite a bit of metal on the bottom front.
Old Aug 7, 2006 | 11:30 PM
  #61
shr00m's Avatar
The front is shorter then the the back on the 4th gen panels. Getting the window seals lined up on top will the leave the front being shorter then the rear. To help cover it, I epoxied the 3rd gen lower door panel seals to the bottom of the 4th gen door panel. It's add's an inch of fluff at the bottom.
Unless you're running lambo doors no one will notice.
Kevin D.
Old Aug 8, 2006 | 05:16 PM
  #62
ReidK's Avatar
so you used part of the 3rd gen panel? I'm not quite sure what you mean could you post a picture? Thanks.
Old Apr 30, 2008 | 03:32 AM
  #63
358formula's Avatar
Car: 89 Formula Ws6
Engine: 358 Tbi
Axle/Gears: stock 2.73 posi
Re: 4th gen door panel teaser..
Originally Posted by stalin05
hey anyone wana come to iowa and do that for me
Did ya ever say how much it was to do all that? And do they come in black?
where at in iowa are you i just did it to my 89 i am still trying to figure out the 4th gen door handels and final fitment
Old Apr 1, 2014 | 09:09 PM
  #64
rooney428's Avatar
Car: 1986
Shr00m - looks awesome! Wish you were in N MS instead of South.. since I'm in Memphis... picking up a set of doorpanels tomorrow to go in my 86... panels are from 96 - in great shape and I think will really give it a good look. Wish they still had the seats but those were already gone.. so looking to either find another set of recover mine to match the door panels
Old Apr 2, 2014 | 12:04 AM
  #65
shr00m's Avatar
I really thought I had updated this. Per another thread I did reply to:
4th gen panels are wider then 3rd gen doors, they are not flat on the back side (they are curved out on the bottom and front), and they are shorter in the front then they are in the back.
Like Wraith said, no matter what you do they are not going to look stock. Whether they look good or not is up to you. My teaser pics were admittedly skewed to not show you the areas I didn't want anyone to see. They still might have worked out had I never put the kick-panels back in. They will hit the kick-panels.
So use this thread as a guide I suppose, but I was never happy with the results and would not recommend trying to cut 4th gen panels to fit. You can manage to get something that looks good with the door closed, but the front and bottom will never look great to me.
I ultimately went with the guts of a 4th gen panel fiberglassed to a blank 3rd gen panel/top. Build site is at http://www.ms-fbodies.com or in the stereo forum.
Kevin D.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
