T top leak on 83 z28, help please
Old Jan 9, 2005 | 02:41 AM
dennisgramm's Avatar
Car: 1983 Camaro Z28
Engine: 5.0L HO
Transmission: 5speed
It has been raining a lot in Ca., and my t top is leaking several drops a min., and not sure exactly where it is coming from. I examined all the weather seals, they all look good as far as I can tell, no tears, holes,etc. it drips where the large outside plastic piece(this is where the glass fits into). it has three screws fit into it, and it leaks at the front screw and where the gap is where it joins the front seals and frame...the gap between. If I take the t top off, and disasemble the screws, what is inside there, maybe it needs some silicone; or something?, and then re=assemble. I have never tried to take it apart. I even ran a strip of silicone where the glass meets the plastic on the outside just in case it was leaking there, but made no differance. Appreciate any help anyone might have. It seems pretty water tight except on the front where it joins the frame. Thanks, Dennis
DennisGramm@webtv.net
Old Jan 9, 2005 | 09:42 AM
AJT86's Avatar
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
in my 83 SC, i took off the t tops, took off the platics, then moved the t top brackets down as much as i could. this put a good seal on them and they are fine untill summer when i can get new seals
Old Jan 9, 2005 | 12:23 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Yeah I've been enduring the 2 week long rainstorm here in CA too. Use vaseline on all of your weatherstripping (lots of it) until it stops raining, then tighten them down and possibly get new stripping.
Unless you have a garage or other covered area, then tighten the brackets and stuff in there.
And yeah it sucks to drive around and be getting rained on INSIDE YOUR CAR.
Old Jan 12, 2005 | 11:24 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
I tore my t-tops apart expecting to find stuff in there to replace and found it to be amazingly void of anything. Theres a bar and a bracket but theres no seal to replace that repels water. The vasoline trick works for awhile, save some money and get the new seals. I've also found a set of seals at a wrecking yard that were in better condition than what I had so I bought them. It was $5.00. Worth the price. If they work, great. If they dont I'm only out a few bucks.
Old Jan 13, 2005 | 11:52 AM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
Welcome to my world, both tops leak and I have C&C. It's gonna cost me $300 plus for all the weather stripping.
Damn you you damned dirty apes!!!!!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
wayshegoes
Aug 17, 2015 12:00 PM
