how many of yall redid ur own headliner?
Old Dec 30, 2004 | 10:37 AM
89firebirdguy05's Avatar
Car: Firebird
Engine: 2.8
Transmission: 5spd
I wondering how many of yall re did your own headliner yourselves? I need to redo mine..but i wnat to do it myself.i paid 150 to get it redone in my old car..and i dont have the money to be spending on that.haha...well...can anyone give me tips or show me some pics? and how do you take the dome light out? i always thought they were scewed in. but its actually some type of pin with some type of lock on it..well..any help is appreciated! thanks
Old Dec 30, 2004 | 11:24 AM
MNformula350's Avatar
I redid mine myself, about 2 years ago now. I used tweed for mine. it is relativley simple. Just make sure you get all of the old foam (black stuff) off the after you get the material off. Then i used 3M spray adhesive in a can. I also did my t-top shades as well.
Old Dec 30, 2004 | 11:26 AM
Car: Firebird
Engine: 2.8
Transmission: 5spd
man that looks good..i wish i had one of those overhead consoles...but..istill need to figure out how to remove the dome light
Old Dec 30, 2004 | 11:28 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: how many of yall redid ur own headliner?
Talk to Shane aka therckid...he is the resident headliner expert here on tgo. He did his in fur and is getting ready to change it over to neoprene...
Old Dec 30, 2004 | 11:29 AM
Killer headliner job there....
Old Dec 30, 2004 | 02:55 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Re: Re: how many of yall redid ur own headliner?
Hey Cap'n, I hear he's the resident expert on all things automotive?!? "d00d!" LoL
Old Dec 30, 2004 | 03:19 PM
CaysE's Avatar
Hi, real resident headliner expert here. Please refer to the headliner link below:
Old Dec 30, 2004 | 06:25 PM
Frank_Blotto's Avatar
Car: 87 Camaro Z28
Engine: LG4, CCC
I redid mine in fuzzy leopard print. I wish I had some pictures. It's bitchin, and not that hard to do. Just make sure you get off all the old material, and get a good quality replacement. Be careful with the fiberglass board, as mine was broken in a couple places around the edges. Take your time. It's actually kinda fun. Oh, and it really helps to have a 2nd person to help take it out and put it in.
Old Dec 30, 2004 | 07:01 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
well if I may I redid mine as well and put a light weigght black felt, but to get to the question, all you need to do is take a pick and pry a little around the edgle of the lock washer til you can get a pair of pliers on it and pull it off. Pretty simple really.
Old Dec 30, 2004 | 09:27 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Going on 8 years with mine along with the visors.Had enough material left over to make some T-tops covers too..
Old Jan 1, 2005 | 10:27 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
I did mine this summer... only things I can say is spend the time cutting it right, I have bare spots showing with the ttops off
And if you use clothespins to hold the edges down while its drying, mmm maybe just dont, the glue soaked through in some spots and I have permenant marks there now :P
otherwise for $25 it sure beats what was in there
Old Jan 5, 2005 | 07:20 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
looks like a nice job you did with the C&C t-tops there.
Old Jan 5, 2005 | 07:48 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Do you mean my C&C......Like DR1 said make sure you cut with xtra material to wrap around & over the frame.When i did mine i cut the head liner with 4-6 inches to spare.So i could wrap it over the frame w/out stretching it too much.Otherwise your headliner will want to pull out.I also cut mine out to the edges of the B pillars & over the holes where the t-top pins f=go into the body.This way the headliner material is under the B pillar/T-top plastic trim.Really helps with minimizing squeeks/rattles.The t-top covers were made using cardboard..
Old Jan 7, 2005 | 08:12 PM
82knightrider's Avatar
Transmission: TH200C....700R4
heres mine,
Old Jan 7, 2005 | 08:13 PM
oops........
Old Jan 10, 2005 | 08:34 PM
mist1006's Avatar
Car: 86 Camaro Z28
Engine: 350 built
Back:
Front:
My hubby an I did most of it... Have enough material to do my sunvisors too..
Old Jan 10, 2005 | 08:35 PM
mist1006's Avatar
Car: 86 Camaro Z28
Engine: 350 built
As you can see from the back of mine, my headliner cardboard was torn... so we fixed it with thin cardboard... Easy
Old Jan 11, 2005 | 06:15 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i would recomend about 4 cans of spry glue per headliner. the more coats of glue the more rock hard the thing is, mine is rock hard, ROCK HARD. also, like mist1006 my board was in sorry shape, i lined the back with fiberglass fabric that can be found at any autozone or schucks. good luck with your job. see the thread about my recovering jobe HERE upon looking at that thread i relised i never posted finished pictures. i will try to do that in a couple of days.
Old Jan 13, 2005 | 12:40 PM
Thunderboy's Avatar
Car: '90 Camaro RS T-Top
Engine: 5.0 TBI
Transmission: TH700R4
I did mine too. Luckily the foam backing was in near perfect condition. I used contact cement and worked in sections. Just make sure you get enough extra material front and back, because when you work it around the tight corners, it uses up some lenght (I'm talking from experience here!).
I tried to find an overhead console that I could adapt, but I had no luck, so I just covered it up as it came from the factory. I used a fabric made specially for car headliners, that already comes with foam backing. I had the sunvisors redone by an upholsterer (I thought about duplicating the factory stitching) but after seeing that the machine would have to sew through the cardboard base, we decided only on gluing the fabric. This is normal fabric, without foam backing, and I found one with a very similar color to the headliner material.
It just takes a little patience and clean working for a neat result, and the change was very satisfactory.
Old Jan 13, 2005 | 12:42 PM
Thunderboy's Avatar
Engine: 5.0 TBI
Here's another shot. In the previous photo the dome light looks yellowish, but It was a camera effect, it doesn't look like that in real life.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
PurelyPMD
May 5, 2016 04:57 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
MORREALE5
Sep 13, 2015 09:01 PM
blackbmagic
Sep 8, 2015 10:36 PM
