hatch pull down vertical plastic slider guides
Old Jan 12, 2005 | 05:04 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the part of the pulldown assembly where it rides in the two grooves and has white plastic guides, if the guides are missing then does that mean the assembly is junk ? them missing causes the latch parts of the assembly to be sloppy loose in the main assembly
vertical tracks
thanks
Old Jan 12, 2005 | 08:18 PM
f1ls1's Avatar
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
TDS sells the sliders.
Old Jan 12, 2005 | 08:47 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
oh, ok, lol. thats an easy answer, damn
:P
how much they cost and whats one of these whole assemblies worth no more than- if it needs the sliders but is otherwise fine ?
are they all the same regardless of year and body ?
82-92 F body*
thanks
Old Jan 12, 2005 | 09:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The plastic slides or guides will run you around $22.95 and the plastic nut is $7.00 if you want to get that as well. I just ordered a set from Lonsal on monday and hope to get them about friday. Then I can finally put the hatch down and take the weed-eater line out. Thank goodness I have a carport.
Old Jan 13, 2005 | 09:03 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
I got about 10 of the plastic nuts out of some Cadillacs when I was in the bone yard. Should give me about a 20 year supply.
Jim.
Old Jan 14, 2005 | 09:08 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
lol
you sound like me, saving items from parts vehicles, a supply, hehe
thanks
Old Jan 14, 2005 | 10:59 PM
Jay3wpb's Avatar
Car: 1989 Camaro RS
Engine: 305 ci V8
Just installed a new hatch motor, need to get those plastic guides. thanks for the tip.
Problem is after install, it pulled down and now wont move at all??????? PLease help as I cant close it now.
Old Jan 15, 2005 | 04:29 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
am glad to have helped indirectly by posting topic that is in regards to a problem with your hatch pulldown and includes how to fix info
thats what a message forumm such as ths one is all about and for
Old Jan 15, 2005 | 04:54 PM
Jay3wpb's Avatar
Car: 1989 Camaro RS
Engine: 305 ci V8
Got everything i need from TDS. Thanks again!
Old Jan 15, 2005 | 07:56 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
cool lemme know what it is like replacing/installing them
and wheres the hatch release buttn located in the camaros ? i need to find it in this 87 so i can save it for my 82 ta
thanks
Old Jan 15, 2005 | 08:03 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
delete
Old Jan 15, 2005 | 08:54 PM
Jay3wpb's Avatar
Car: 1989 Camaro RS
Engine: 305 ci V8
Hatch release is located on the center console just below the shifter.
Installing is easy once you get the parts in
in the correct order. The owner of TDS sent me an installation guide as a link,
but a haven't figured out how to do that yet.(its a PDF) let me know if you need it
and i'll get it up here for ya somehow.
It was very helpful, Step by Step, pictures..
Old Jan 16, 2005 | 01:21 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Anyone can download most of the instructions for the products I sell from my web site. The nylon guides are TDS p/n 101170. The instructions are in the "Documentation" section in the lower right side of the main page.
Lon Salgren
Top-Down Solutions
Old Jan 16, 2005 | 09:35 AM
Jay3wpb's Avatar
Car: 1989 Camaro RS
Engine: 305 ci V8
thanks Lon!
Old Jan 16, 2005 | 09:53 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
not a single switch or hole in the console in the camaro i took the release from
hmm
there is a blue toggle switch in the dash l;eft of the column right below headlamp switch i removed
a PO must have added it in later
doh.,
Old Jan 16, 2005 | 10:05 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If the car came with the hatch release switch, it would be in the center console between the two power window switchs. There were some models that did not have the power windows or hatch release switch option. There were also others that had the power windows but not the hatch release switch.
Old Jan 16, 2005 | 10:54 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
none, neither, nothing power in the whole car cept for steering but thats not electric hehe
thanks
Old Jan 16, 2005 | 11:35 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I bought the sliders from TDS and they worked great. Instructions were easy to folow as well.
Old Jan 17, 2005 | 10:18 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
well im just gonna toss this assembly in the car for scrap since it needs sliders or whatever, i dont want ot mess with it all plus id have to find an 82 switch for FB's and wires, theres no way that can happen
thanks
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
hydrolic144
Sep 8, 2015 06:55 PM
zayne0
Aug 24, 2015 07:22 PM
madsv1000
Aug 20, 2015 06:45 AM
