4th gen Seat Belts in 3rd gen Camaro
Old Jan 16, 2005 | 08:58 PM
souperman28's Avatar
Car: 89 IROC-Z
Sorry if this was posted in another thread, but i am changing my interior color to black and i came across some 2002 trans-am front seat belts and i was wondering if there was a way to make them fit in my 3rd gen camaro. my problem is that the 3rd gen seat belts have two motors and the 4th gen has one. so what is the solution to that?
Old Jan 18, 2005 | 01:49 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
4th gen front and rear seatbelts have been put into 3rd gens and they truely just bolt in. Lacking the bottom retractor doesn't make a functional difference. Depending on how picky you are, the bottom trim may not look perfect because of the notch and tabs in the door sill plate for the retractor. One option is to get sill plates from an 82 or 83 f-body. They actually used a top retractor only system in those years so there's just a little slot for the belt to come through on the bottom as it is in 4th gens.
Old Jan 18, 2005 | 01:52 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I tore the plastic trim off of my old belts and used them to cover up that notch in my door sills. I just have to glue them down. I reccomend the swap, I love the new belts.
Old Jan 18, 2005 | 02:55 PM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
Is there anything special about hooking up the rear shoulder belts? I'd like to have those in (they came with the set of 4th gen seats I got) but I suppose I'll have to hunt down the buckles for them.
BTW, souperman, how much did that set of belts cost you?
Old Jan 18, 2005 | 08:12 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
they should just bolt into the exiting latches.....
Old Jan 18, 2005 | 08:33 PM
Car: 89 IROC-Z
i got 02 black leather seats front and back plus all the seat belts for 450 from synergy motorsports, i have tried everything to just to bolt the new seatbelts in but its not going to happen. the motor on the roof bolts right in but the bottom is my problem its supposed to bolt to the side, but the plate where the old motor was mounted is totally wrong for the situation. i will take pictures of it, it is to hard to explain.
Old Jan 18, 2005 | 09:18 PM
Car: 86 T/A
Engine: HSR 355
Unbolt that bracket, its like 3 screws. You may want to remove the seats for ALOT of room to work, but its not necessary.
Old Jan 18, 2005 | 10:50 PM
Car: 89 IROC-Z
so the flat bracket unbolts i thought it was welded in.
Old Jan 18, 2005 | 11:00 PM
Car: 86 T/A
Engine: HSR 355
Not in my car.
Old Jan 18, 2005 | 11:19 PM
Car: 89 IROC-Z
ok it is bolted in but when i take it out, is there a spot for the big bolt to mount the new sealt belt?
Old Jan 19, 2005 | 07:57 AM
Car: 86 T/A
Engine: HSR 355
There should be. Did you even look? It's not like its going to be hiding on you. It either right underneath the bracket or its not.
Old Jan 19, 2005 | 08:06 PM
Car: 89 IROC-Z
sorry for the confusion i put them in with alittle but of tough love. but i did it thanks for the help.
Old Feb 15, 2014 | 01:30 AM
86F.BiRD's Avatar
Car: 1986 Pontiac Firebird Base
Engine: SBC 350
Transmission: Borg Warner T-5 World Class
Axle/Gears: 4th Gen Rear with 3.73s
Re: 4th gen Seat Belts in 3rd gen Camaro
Can someone that has done this swap please post some pictures. Thank you!
Old Apr 13, 2014 | 10:03 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Bump looking to do this myself since i cant seem to locate a set of third gen black seat belts
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 22, 2015 07:13 PM
reiderz iroc
Aug 13, 2015 04:57 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
