AC to non-AC controls ..question
Old Jan 17, 2005 | 06:56 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
ok i have a 91 rs with AC , i took out all the AC stuff, and bought the AC delete heater box and interior controls, how do these controls work and hook up? what do i do with the vacuum lines that where in there before? thanks
Old Jan 20, 2005 | 05:35 PM
BOTTLEDZ28's Avatar
Transmission: A4
why do you even want to change it out. id say leave it in there. Did you change out the blower motor to the non A/C one? If you did then there will only be 3 speeds on it now for the heat. The blower motor that comes on A/C cars has 4 speeds, therefore you would have to leave the HVAC controls in your car if you removed the A/C but kept the blower motor. If you took the 4 speed blower motor out and now want to put it back in then you will have to make some modifications to the fan and or the box.
Old Jan 20, 2005 | 10:22 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
im just gonna change the face plate on it thats all, i really dont care, but if it was my way i would have changed all the ductwork to cable controled to make it a true NON A/C car. but its way too much work to do out in the cold here. so im just gonna switch the face plate just to sooth my OCD... lol... but cant i just plug in the blower onto the old harness? im still waiting for the dam thing to come in the mail so i havent got a chance to play with it yet
Old Jan 21, 2005 | 07:56 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
FWIW I left all of my old controls in, replaced the blower box (evaporator box) with a non a/c one like you did. If you just remove the small surround panel on your control panel, it will remove all of the a/c lettering and then you just put the non-a/c surround over it and use the original controls. I think your car is the same, anyway, it worked for me w/out changing out all of the controls which looked like a PITA. BTW my car is an 83
Old Jan 21, 2005 | 08:49 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Just change the resistor in the blower box. The A/C one has an extra terminal for 4 speeds. No need to cut the wires going to it or change to the non A/C connector. You should use the non-A/C motor, it's shorter than the A/C one.
Old Jan 21, 2005 | 10:12 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
wow, u guys were a BIG help to me on this project. cant even explain it, im very greatful to have such an awesome source with loads of info and smart people. :hail:
tmellott89
Oct 14, 2015 02:06 PM
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
tattmann
Sep 27, 2015 05:20 PM
Damon
Sep 26, 2015 04:29 PM
