Ground effect on door removal?
Old Jan 18, 2005 | 09:10 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I am changing door on my car and need to change the ground effect piece on the door. Looks like it is rivited in place. Can I drill out the rivits? Can I use self tapping screws to mount the new piece on?
Old Jan 18, 2005 | 10:50 AM
TBones87's Avatar
Car: 87 Camaro LT.
Engine: 305 LG4
Are you sure it is riveted on? My gfx had no rivets at all
Old Jan 18, 2005 | 10:53 AM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
When you take the trim panel off, there should be access holes to the back side of the panel and the speednuts holding it on the door.
(Unless they're not factory)
Old Jan 18, 2005 | 10:55 AM
Car: 1971 Camaro
Engine: 427
Trim panel? Are you talking about the door panel itself?
Old Jan 18, 2005 | 11:01 AM
KEVIN G.'s Avatar
Engine: 305 CARBED
No, you need to take the trim panel off to gain access to the speednuts on the backside
Old Jan 18, 2005 | 11:32 AM
Car: 1971 Camaro
Engine: 427
What trim panel are you talking about? The ground effect itself? It is what appears to be rivited. What other trim panel is there?
Old Jan 18, 2005 | 11:38 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
remove the door panel and on the backside of the door will be 3 or 4 speed nuts. there are 2 other speed nuts on the very edges of the door, these are exposed, ie. not behind the door panel.
Old Jan 18, 2005 | 11:55 AM
KEVIN G.'s Avatar
Engine: 305 CARBED
Sorry, I'm used to describing things to technicians, and don't think about the everyday terms we use, as being non-layman terms.
You must remove the interior "trim panel" the fabric covered cardboard piece that is what you see when the door is closed and you're driving. It covers all the hardware, and the arm rest and handle bezel are part of it.
They are retained by screws and multiple clips, as well as the upper retainer...
Depending on whether or not anyone has been into this door before, there should also be a weather barrier, a large piece of plastic or tar paper covering all the acces holes to the window and gears for the window regulator...at the bottom of the door, on the inside, there will be some quick, or "speed nuts" holding the gd effects to the door.
Old Jan 18, 2005 | 01:02 PM
Car: 1971 Camaro
Engine: 427
I see. Thats what I needed to know. The door panel. Thanks !
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Oct 3, 2015 05:34 PM
mikey8494
Aug 22, 2015 07:57 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
92firebirdchris
Aug 14, 2015 11:56 AM
