Improving Factory 91 seats
Old Feb 7, 2005 | 10:01 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
One reason I bought my car was for the interior being in excellent condition, (even at 145k miles). However the seats have faded from black to purple. I am looking for opinions. Should I just spray the purple parts with the interior spray paint? Or should I spray the seats all the way with the interior spray paint? Or should I take the seats off (understanding that isn't that hard with hognose pliers) and rit dye them? Here is my canvas cover before the interior spray paint. I'll post pictures with paint later.
From
To
The seats factory scheme or all black?
Old Feb 7, 2005 | 10:45 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Well, the problem with alot of dyes is that it makes the fabric crunchy...and it stinks. Wonder how much it would cost to just have those parts recovered?
Old Feb 7, 2005 | 10:48 AM
anondude13's Avatar
Just FYI, 4th gen seats are a direct bolt in.
Old Feb 7, 2005 | 10:54 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if it was the carpet... id say spray it.. ive seen excelent results.
if it was leather, id say dye it.. ive also seen good results.
but cloth seats would have to be recovered.
if you look at the cost of recovering the seats (assuming you're not doing it yourself)and then look at the cost of 4thgen seats, you'll want to get the 4thgen ones.
they have a updated, more comfortable modern design... the foam isnt as old, springs arnt weak, ect...
so my advice would be, just buy 4thgen seats.
Old Feb 7, 2005 | 05:52 PM
Mr. TurboTA's Avatar
Hi!
I have had pretty good luck with redying frabic seats the same color!
Just do what the can recomends.
Spray lightly, and brush after it is dry! Do this a couple of times.
You may have to do it more than once, and it may refade, but it is cheaper that redoing the whole interior!
Good luck,
George
Old May 17, 2005 | 06:09 PM
Car: 91 Camaro RS
I know I'm bring my post back from the dead, but I did my rear seats last week and they look 10 times better than before. To soften them up between layers I used "Tuff stuff" cleaner (fabric cleaner available at walmart for 2.44 a can) and worked it in my fingers. They still are stiffer but they look much better.
I'm going to do the front seats once school gets out.
Old May 18, 2005 | 08:19 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Very nice.
Old May 18, 2005 | 08:57 AM
Car: 91 Camaro RS
Originally posted by Jim85IROC
Very nice.
Thanks, it takes a lot of coats to look good. Also I had to use some industrial duct to mask the seats, masking tape and these seats doesn't work.
Old Jun 5, 2005 | 10:38 AM
Car: 91 Camaro RS
Well I am finished for the time being on dying them, however little to my knowledge they sell a gloss black dye, I used the flat black. Sometime during the summer I'll probably go over them again with gloss black.
As you can see some of the purple still shows through, so far the entire interior took 5 cans. I still love these seats about a million times better than the 93-97 plain jane gray camaro seats.
Old Jun 5, 2005 | 10:39 AM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
Huge improvement, nice job!
Old Jun 5, 2005 | 10:43 AM
Engine: 5.7
Gloss black? I think the flat black looks factory and original. If you coat them with gloss...i think it will look pretty tacky.
So, are you wanting them to be shiney? or is there another reason? BTW, they do look alot better
Old Jun 5, 2005 | 11:55 PM
Car: 91 Camaro RS
Well after thinking about it gloss does seem a bit outrageous, I think I'll find some test material first. If I don't go gloss, I think I need a few more coats, I want it so black that I can't even remember them looking purple.
Another note, everyone said that after dying the fabric would be completely stiff. However with the use of interior fabric cleaner you can't even tell that they have been dyed based on texture.
Old Jun 6, 2005 | 01:35 AM
camaro_doc's Avatar
Gladstoneiroc,
Old Jun 6, 2005 | 01:40 AM
camaro_doc's Avatar
Sorry for the double post guys!
Gladstoneiroc,
You did an amazing job dying the seats and carpet. Whst i wanted to know was what kind of dye did you use and where did you get it and how much did it cost? I think that this would be the perfect touch for my IROC'S interior.
Thanks for any help,
Matt
Old Jun 6, 2005 | 09:40 AM
Car: 91 Camaro RS
Re: Sorry for the double post guys!
Originally posted by camaro_doc
What i wanted to know was what kind of dye did you use and where did you get it and how much did it cost?
I used Dupli- color's vinyl and fabric coating in flat black. It is available in some colors at Walmart and most automotive parts stores, which will have more colors. It cost $3.8x at walmart a can and $4.88 at Advance Auto parts. At this point I've used 5 cans on my interior, including some quality duct tape I have about $20 in the project.
Old Jun 13, 2005 | 12:59 AM
camaro_doc's Avatar
Great! I know what the old roc is getting soon. Thanks for the info.
Have a good one
Matt
Old Jun 13, 2005 | 01:17 AM
Justin Horne's Avatar
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
I ought to pick some of that up.. I have the exact same interior, except mine's still purple.. I actually never knew the difference until I saw this.. Good job.
Old Jun 14, 2005 | 03:09 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Gladstone, did you use Duplicolor's VS3 (flat black) Vinyl and Fabric paint on the canvas cargo cover? Just want to make sure, as this thread had spurred me to fix my sun-bleached cover. Thanks.
Old Jun 14, 2005 | 09:06 AM
Car: 91 Camaro RS
Jade Grey, that's exactly what I used.
Old Jun 14, 2005 | 10:58 AM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
Wow your seats are in amazing condition considering the year and mileage. They're just as nice as the ones in my car and mine has 46,000 miles. Is there any secret to keeping them in such good condition... i recently put some seat covers in my car to keep them looking good but i really hate the seat covers because they're meant for 4th gens and dont fit right and they dont look that good either....
Old Jun 14, 2005 | 11:21 AM
Car: 91 Camaro RS
Well I bought my car with 132k miles (now has 147k) and one of the biggest reasons was due to the interior's condition. However a small hole is starting to form in the drivers seat area . Its the only flaw so far and its driving me crazy. Also get some foam carpet cleaner and work it in with you hands then vacuum, it keeps the seats clean and soft.
Another note, if you have a stain and it doesn't come out. You should clean it very well and the dye it. It makes it nearly invisible.
Old Oct 5, 2006 | 10:46 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
just wondering how the dye has held up for you? i found some seats that i want but they are kinda faded likethat. but they are at a good price and kinda rare so if the dye stuff works good i might try it out.
Old Oct 5, 2006 | 11:41 PM
Car: 91 Camaro RS
They have held up alright, but here is some added information. Use atleast 3 coats of gloss black, not flat black. The reason why is that gloss black looks closer to original and does not fade as much. I think the lifespan of the dye is somewhere between 2 and 3 years in a daily driver that soaks up the sun all summer long. Finally, dye the carpet and kick panels and buy some quality black floor mats.
Old Oct 6, 2006 | 08:25 AM
Car: 88 IROC
well im just going to do some seats. i found a set of racing seats from a friend but they have a little bit of blue on them and i was thinking about dyeing them black or grey. how many cans did you use on those front seats? if it will last 2 or 3 years that is perfect for me b/c im just going to put these in so i can have my stock ones recovered but i dont know how long that will take.
J-money
Jan 4, 2019 09:45 AM
HP52TA
Feb 3, 2018 10:51 PM
hdis2002
Sep 8, 2015 02:52 PM
scottmoyer
Sep 7, 2015 07:06 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
