Fender/Bumper/Door differences '90 vs '92 model year
Old Feb 10, 2005 | 06:50 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is time to finaly get some new body panels and kick off the re-build since my wreck two years ago. What were the differences between the doors, bumpers, and fenders between the 90 and 91/92 model year changes. My research shows me that there are slight differences (longer?) in the front fenders for the 91 year when the GXF changed? Is this correct or can I use 91 or 92 fenders on my 90? I am under the assumption that the doors and bumpers are identical. I have the opportuniny to pick up both bumpers and a door really cheap and fairly close to me. I wanted to varify that a fender would be compatible with my model year.
Thanks in advance.
Old Feb 11, 2005 | 04:43 AM
Spdfrk1990's Avatar
The doors and fenders are the same as far as shape there are some holes you have to drill for the 92 gfx that dont line up. I just aquired the rest of the 92 gfx for my 90 now I just need some1 to make me some cardboard templates or something to drill the holes i dont want to guess at it i want them exact. If any one has done the conversion or can make us some templates that would be great. The rear quarter peices have the holes in different spots also and the rear bumper bolts up the same. So everything needs new holes drilled except the rear bumper and the front bumper is the same. Oh the front gfx peice also bolts all up the same except on the fender where u have to cut slits I have the templates for that but i think ill get new fenders anyway. So the conversion is def not just unbolt then bolt up but you wouldnt have to buy any new sheet metal if you didnt want too.
Old Feb 11, 2005 | 01:19 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
That makes a lot of sense. I knew the differences were small. I am keeping my 90 GFX but don't want to drill new holes if I can avoid it. Looks like I will hold out for some 87 thru 90 stuff. Thanks man.
Old Feb 11, 2005 | 08:00 PM
Spdfrk1990's Avatar
No problem, yeh drillin holes for me isnt a big deal i got it all apart any way and ill just weld in the old holes.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Grant2k
Jul 10, 2018 04:01 PM
Linson
Aug 21, 2015 02:12 PM
Fronzizzle
Aug 9, 2015 01:15 PM
MENINBLK
Aug 5, 2015 11:58 PM
