I posted this a few months ago and every one said check the seals well i checked them they are fine no leaks anywere. When ever it rains really hard i get water on my drivers side floor.
Im wondering if maybe a drain hole mighr be clogged in my vents? I can not figure out were that water goes that ended up in the plastc vent outside the car could it be leaking in from there. I am going to be putting new carpet in soon and i want to pin point this so it does not trash my new carpet.
i noticed when i took my car of the road and pulled out the carpet there was some water, not alot but it was still damp on hte passangers side. i couldnt find where it was comming from either. and i barely ever drove my car in rain. only when it was the only option (when the daily beater wouldnt start)
That sounds like the heatercore i wish it was the heater core that i can change and fix but since its on the drivers side im stumped its like right in the middle by were you left foot would go.
Im having that exact same problem of water on the drivers side, i put a new windsheild with new seals in, same problem, could it be the door seals??
any help would be appreciated
I think you hinted at it, but check the cowl drains. I haven't had to deal with this on a thirdgen, but on some of my older cars, the cowl drains were the issue for water leaks into the passenger compartment. Might even be a rust hole in there from leaves and crap getting stuck and retaining moisture against the steel. I guess you could check this by using a hose to spray into the cowl area only...if you see a leak, then voila, culprit identified.
I will have to check that i can rule out my windshiled i had a new one put in and i still have a leak so i know it is not that.
I had the same problem after replaceing a windshield,found it was the bottom of the windshield wasnt sealed.the glass place took a tube a sealer an sealed the corner no more leak.
Maybe the speedo cable grommet? Its right above your footon the firewall, just past the under dash cover.
