New 97-00 console, but where to put the window and trunk release??????
Old Feb 25, 2005 | 04:00 AM
globalco's Avatar
Since the 82-92 console had places for the window and trunk release buttons, where do you put these when you update to a 97 and later console?
What kind of switches do you use????
Jim
Old Feb 25, 2005 | 04:23 AM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
I'd say cut a hole.....if i werent a perfectionist.
I am doing a custom smooth console top on mine and am mountign my hatch and window switches inside the front of the glovebox, out of site and if you f up your holes no one will see
Old Feb 25, 2005 | 11:45 AM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
This thread may be of some help:
https://www.thirdgen.org/techbb2/sho...hreadid=188026
I thought deadbird's idea was pretty cool.
Old Feb 25, 2005 | 12:43 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
when i added my hatch pop, i mounted it to the dash...my car originally didn't come w/ one, and there was an ice spot on the left side of the drivers dash, just under the vent i suspect, i put it there. I can't rmember however, since i now just use the 4th gen hatchpop seutp.
Old Feb 25, 2005 | 01:59 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I think that they look the best inside the ash tray/coin holder.
Old Feb 25, 2005 | 10:50 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i bought a convertible top switch plate from the dealer for a camaro. you have to do a lil filing to the hole, but the hatch pos switch will pop in and stay.
the plate replaces the coin/junk tray.
like 4 bucks at the dealer. make SURE you get the right color.
Old Feb 27, 2005 | 11:23 AM
Tibo's Avatar
Car: 1991 Z28 Vert
So what is the part number?
Old Feb 27, 2005 | 02:02 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
not sure of the part #, its installed on the car.
just go to the dealer and tell them you have a convertible camaro, and you need a cover plate for the covertible top switch.
97-99 are grey
00-02 are ebony
AT and 6spd are different so specify.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
smooth
Aug 18, 2015 06:34 PM
Firebird sweden
Aug 16, 2015 05:02 PM
mx127
Aug 10, 2015 08:13 AM
