more 4th gen console questions
Old Mar 12, 2005 | 03:50 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
I know I'm beating a dead horse here, but I can't find what I need from searching so here we go. First off I have the 97+ manual console, it has 2 "prongs" on the front sides of the console, they don't seem like I can attach them to anything so should I just dremel them off? Second, I had to take out my radio pod to get the console around the e-brake, now I'm having a hard time getting them both to sit right. Is there a better way to get it in without taking out the radio? I thought this was going to be a bolt in operation but its taking a bit more work than I thought.
Old Mar 12, 2005 | 04:08 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
I dremeled the notches off, in fact I cut the console until it was flush with the cupholder to give me more room to play with (I did mine on a camaro though), it takes alot of work and shifting things around, but it'll get there
Old Mar 13, 2005 | 12:23 PM
Car: 1990 Formula
Well I dremeled off the things on the front easily enough, but I still can't get it around the e-brake with the radio pod in. And when I take the radio pod out to get the console in, then I can't get the radio pod to go back in
If anyone has any tricks to share, please do so. I'm gonna step away from it for a bit before I decide to smash it into pieces...
Old Mar 14, 2005 | 12:19 AM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
you did right by cutting the tabs off, not needed in our cars. pull the E-brake handle almost stright up. nose the console in under the pod and then set it in. thats about the only way to do it unless you unhook the cables at the Y under the car. be sure you have the trim plate out when doing this also.
also where are you putting your mirror and window switches.
if i can get time i will take some shots of what i did.
Old Mar 14, 2005 | 12:33 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
I just installed mine this weekend heres what i did. First i took a hacksaw and cut the ears off of the front of the console. Then with the radio pod installed i took and raised the e-brake all the way up. Then i took the console and slid it down over the e-brake. Then slid the console down between the seats. With the E-brake all the way up you should have a couple of inches to play with forward are backwards with the console. Then once my console was all the way on the floor i had to slide it as far foward as i could. Then i could see the two mounting holes in the floor through the console(where the factory ones bolted). Then i put my shifter **** on and put the E-brake handle back on and was finished. If you have any questions you can PM me.
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Oops double post
Old Mar 14, 2005 | 12:40 AM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
not nessicerily a double post, i didnt mention taking off the E brake handle. that DOES make it alot easier. BTW once you get it over the handle, release the handle tomake other adjs easier once its on.
Old Mar 14, 2005 | 08:40 AM
Car: 1990 Formula
I got it on yesterday, had a friend come over to give me and extra set of hands which made it much easier. I took the radio out, put the console in, slid the console back some to install the radio then pushed the console forward to where it should be. Its a tight fit but its in there. Now I have to mount the window/mirror switches. When all is said and done I think my new interior is gonna look really nice.
Old Mar 14, 2005 | 11:37 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
here are a few pics of what i did with my switches.
http://www.pontiactorque.com/quickch...sole_00002.JPG
http://www.pontiactorque.com/quickch...sole_00007.JPG
http://www.pontiactorque.com/quickch...sole_00010.JPG
Old Mar 15, 2005 | 06:33 AM
*F-BodyFanatic*'s Avatar
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
I did this swap also, except I got the late-4th gen console (the one with 4 cup holders). I need to find somewhere to mount my switches. I liked the mirrors on the side, like shown above. I don't smoke, so I'm thinking the window switches will get some kinda fiberglass plate in there. Right now there's just lose inside, lol. My power mirrors are just hanging out underneath cuz I didn't have anywhere to put them... and I rarely adjust my mirrors. I'm hoping to break into that project sometime this weekend. I installed the console waaaaaay back in July, so it's about time!
Old Mar 15, 2005 | 08:09 AM
BlackMagic's Avatar
Car: 1986 Firebird
will the automatic 4th gen consoles go in as well...or are the manuals the only one to switch over?
Old Mar 15, 2005 | 08:24 AM
Engine: TBI 5.7L v8
Do a couple of searches on this, you'll find all the information you need. It's not as easy of a swap. Everything does not line up the same...
Old Mar 15, 2005 | 09:21 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Fanatic im like you , i dont smoke and wont let anyone that has just smoked near my car. as for the ashtray im a functional minded person so i use my ashtray for change or the occasional oddor end. the lil change throth i use for my gas cap key and i use my cup holder for a cellphone seat.
heck , the lil light that comes with the ashtray even works.
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
