Berlinetta Radio on a Stick
Old Apr 9, 2005 | 10:02 AM
snyperz28's Avatar
Car: 1989 Pontiac Firebird
Engine: 2.8 V6 (soon to be 350)
How the hell do you get that out? I am trying and trying...that whole console seems to be a maze of bolts.
Old Apr 10, 2005 | 11:34 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Once you remove the trim panel from the shifter and behind the radio you will have access to all the screws holding the radio in place.
The part of the radio that is "on a stick" is only mounted by a few 7mm screws at the base of the unit. once the screws are removed you need to use a screwdriver to move the retaining clip out of the way and then you can pull that part of the radio out.
(You know how the radio rotates one "click" at a time ??? that "click" is caused by the retainer clip ) You should have no problem seeing it.
When the top half of the radio is out of the way you need to remove the 2 7mm screws holding the reciever (silver box) bracket & the 10mm nut at the front of the unit. Then that part of the radio can be removed.
I hope that helps !!!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Lbibb
May 5, 2016 12:00 AM
Linson
Oct 1, 2015 09:50 PM
rusty vango
Sep 29, 2015 02:44 PM
