prepping car
Old Apr 18, 2005 | 05:40 PM
89firebirdguy05's Avatar
Car: Firebird
Engine: 2.8
Transmission: 5spd
prepping car
I am currently sanding down my car...just taking off the clear coat and some base. It seems to have been painted before right over the original paint i guess. But after i get down to it, it seems to be alright. So my question is, I am priming it with some of this spray primer. its like 5 bucks a can. I and doing one coat. then sanding it with like 220 then putting another coat then wetsanding that to get the overspray off..If i dont go to the bare metal will this primer and method work?
Old Apr 18, 2005 | 06:35 PM
Car: Firebird
Engine: 2.8
Transmission: 5spd
anyone?
Old Apr 18, 2005 | 06:39 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i dont know anything about body work but i tried the same method before back in high school and i would stay away from it if you want a good looking paint job.
Old Apr 18, 2005 | 10:53 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
it can be done it rattle can but most will say no. It is not the best way to do it though. I rattled primer the front half of a bird last summer before painting. I dont beleive all the wetsanding is necessary since it is rattle. When i did it, i sprayed a couple light coats till it covered. I did no sanding unless something fell in the primer however there tends not to be much since it dries to fast. To play it safe, i would say spray a couple light layers and wetsand the last layer. 220 is a bit too much, i would use 600 or maybe a 1000 grit. Then just spray your paint and your done. Im not an expert at this so wait for some others to chip in their advice before taking mine.
--Goodluck
Old Apr 18, 2005 | 11:22 PM
jay92,85,79's Avatar
Car: 85z28,
If u use spray cans. Get good paint. Not menards 99 cent crap. Dupont makes a rattle can paint for spot in's. Prob going to cost alot. But atleast u know its going to last a while. The bad thing about rattle can paint is its single stage. So over time it's not going to hold up Buy a cheap gun and a cheap compressor. And use reg car paint. U will be alot happier in the end. Gun 100 bucks compressor 200 /300 bucks than get some dupont nason bc/cc .Are there any dents? If the car is stright. Just prime wetsand with 320 /400 than paint
Old Apr 20, 2005 | 06:58 AM
Car: Firebird
Engine: 2.8
Transmission: 5spd
i was told...if you paint your car the same color as before and if the paint isnt chipped and all that i can just sand off the clearcoat and get it all smooth and just paint over that..is that ok?
MustangBeater20
Oct 29, 2022 09:20 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
