Black stuff on interior welds... can I remove it?
Old May 12, 2005 | 05:01 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
I ripped out the interior, and I see this black rolled on asphalt stuff that's on most of the weld joint areas. Some of it is coming off, and so I'm wondering if it's ok to take the rest of it off. I'm going to be coating the car with a liquid sound deadener, so it will be sealed. I'd rather take the black stuff off now instead of having it come off later and taking my deadener with it. Opinions?
Old May 12, 2005 | 10:24 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
any pictures of this stuff?
Old May 12, 2005 | 11:17 PM
super_kev's Avatar
Car: '85 TA
Sure, why not. Same picture I used for another post in the fab forum, but this works and shows you what I'm talking about. You can see the silver area with black areas. The silver is where the black stuff has fallen off, and where the factory "welds" are.
Attached Thumbnails Black stuff on interior welds... can I remove it?-dash.jpg
Old May 13, 2005 | 03:34 PM
crazyn8's Avatar
Car: 55 Chevy (the only one that counts), 80 TA, 85 TA, 87 FB
Engine: BBC, BBC, SBC, none
Transmission: M-22, TH400, TH350, none
It is a lot of work, but it comes off. It helps seal the seam from mosture; so removing it may open it up to future rust starting point, if you do not get it totally sealed with the liquid sound deadener
Old May 14, 2005 | 01:22 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Just my two cents.....but I am rather fond of POR 15
Old May 14, 2005 | 11:29 AM
crazycrocket's Avatar
Car: 1985 camaro
Remove it, its crap and breaks down over time, If you take it off you will probably find places where rust is starting. Now is the time to fix it and cover it with a good undercoating.
Old May 14, 2005 | 01:18 PM
polishdevil's Avatar
Car: 88 GTA
my father was too after he sand blasted the frame on his 36 buick 4 years ago and painted it....4 years later, frame is still not in use, kept in a clean dry garage and the por15 is showing rust
Old May 14, 2005 | 02:54 PM
1989karr's Avatar
Engine: 3.4 / 5.0
really??? Damn! I'd beter do some reevaluating!!!
Old May 14, 2005 | 04:30 PM
Car: 88 GTA
i can take a picture if you'd like....all their direction were followed...my dad is pissed to say the least. the frame is rather big and it took a while to sandblast. then the money and time spent on the por15
Old May 14, 2005 | 04:57 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Yes, perhaps a picture or two would be helpful. If we see what results perhaps we can all make some good decisions on what to do. I know this is super_kev's topic, but perhaps it can help us all out when it comes to this
Old Jul 11, 2005 | 12:17 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
i took off that factory sealer on the welds and re-sealed it with seam sealer, it comes in a caulking tube so you can use a caulking gun, ive used 2 tubes now sealing everything it drys hard and its paintable after 2 hours, its still flexible so it wont crack or peel off. it kinda feels like polyurethane bushings, really hard rubber. i pay about 8 dollars CAD per tube so im sure it will be cheaper for guys in the US.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
89gtaforsale
Aug 24, 2015 09:32 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
