Dash removal....
Old Jul 11, 2005 | 10:15 AM
iroczz89's Avatar
Car: 1989 irocz convert
Engine: 383 tpi
Transmission: 4 spd auto
Dash removal....
I was wondering if it was possible to remove the dash framework without having to remove the whole console? I am replacing my heater core and am having trouble getting the dash out.
Another question is once i do get that out how is the heater core bolted/connected to the inside of the fire wall?? Thanks for any help!!
Old Jul 11, 2005 | 12:08 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Why are you removing the dash to replace the heater core? That is totally unnessessary.
There is an access panel on the heater box to remove the core.
1.Drain the coolant and disconnect the heater hoses at the fire wall.
2. Remove lower hush panel from bottom of passenger side dash.
3. Remove lower dash bolt just above kick panel.
4. Remove screws that mount the computer, lower the computer and set it aside
5. Remove the heater box access panel. There are four bolts. Three are pretty easy to get at. One of the top ones you'll have to feel for with your hand and use a long extention and ratchet to remove. Pull on the bottom of the dash where the dash mounting bolt was removed to get the access panel out from under the dash.
6. Remove the four screws holding in the heater core and pull it out of the heater box.
Reverse for installation
Old Jul 11, 2005 | 01:12 PM
iroczz89's Avatar
Engine: 383 tpi
Wow---thanks sooo much for the info---saved me from removimg my console for nothing!!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
