rear view mirror and paint
What is the best stuff to use to get a rear view mirror to stick? I've tried a few things and they either don't stick enough or when they do they soon fall off. and whats the best way to like scuffs out your paint? thanks
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
You really need to make sure you:
1. Clean off the window and bracket
2. Let the glue set for a long time- like 2-3 days in some cases
3. Some of the glues require moisture to set up so they say to leave a bowl of water underneath it and close the windows of the car.
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
if theres paint swapped onto ur car from another lacquer(sp) thinner will remove that. scuffs and light scratches can be removed by buffing. i recommend a buffer with wool and sponge pads along with compound. but be careful as you can easily burn thru the paint. if the scratches arent deep you may be able to get them out by hand with some rubbing compound. use good name products for this such as 3M, Mothers, Meguiers, etc....any other questions PM me i should be able to help out.
matt
matt
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I suggest scuffing the area of the glass with some sand paper to give the glue something to work with. But be sure to do it only where the window button goes, and not anywhere else!....apparently the former owner of my car thought doing other areas would be a great idea
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Apr 30, 2019 12:14 PM
