map lights
Car: 1992 Z28
Engine: 5.7
Transmission: 5 speed
map lights
Can someone please tell me if 1992 z28 came with map lights on the rear view mirror. My mirror has it but the connector isnt connected into anything and i cant find the female connected in the headliner.
Thanx
Thanx
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I've seen some with it. I think these only have the driver side light switch though right? But it should be there....if not you just need to snag a connector from a junkyard and wire it into the dome light
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I've found that the other light is either on all the time or when you turn on your headlights (Ive only noticed it when my headlights are on), but I believe its used to luminate the console. Thats where it shines, and the only reason I can think of.
