Shifter setup?
Old Jun 11, 2005 | 02:43 AM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
Shifter setup?
Hey guys, I just got done installing a 350 V8/ th350 setup into my once previously 2.8L v6/ t5 car. Now, I'm kinda confused as to what to do now to get an auto shifter hooked up. When I took out the auto shifter from the 79 camaro, I noticed the floor was still intact minus 4 holes for mounting the shifter and the lil hole and boot the shifter cable came from.
In my 84 Camaro, since it was a T5, there is just a big hole in the floor where the shifter was.
I don't know what a 700R4 shifter setup is like, but I can't use the 79 shifter because the square hole cut out is too big. Am I going to need to weld sheet metal to fill the hole?? Then redrill holes to screw in a shifter?
Any help would be appreciated. If possible, pictures of a 700R4 shifter setup (console top removed or the shifter itself, would be best)
Thx
Old Jun 11, 2005 | 05:26 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
yep weld in a piece of sheet metal to cover thehole then drill new holes for mounting bolts and shifter cable
Old Jun 11, 2005 | 08:57 PM
Engine: 355 TPI
Do you think I'd be able to use the 79 th350 shifter then? Or will only the 700R4 thirdgen shifter setup work?
Thx for info so far
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
topteam54
Oct 6, 2015 12:21 AM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
