what to do with gfx fasteners
Old Jun 18, 2005 | 12:15 AM
VILeninDM's Avatar
I took off everything including gfx's of the car in preparation for stripping and priming. A lot of bolts and screws are really rusty.
People who did something like this (or who otherwise would know what to do), did you reuse all the bolts/screws/nuts, or get new ones? Biggest problem is some things appear as a studs (i.e. one side sits solid in the plastic while a threaded side is sticking out). I don't even know if those ones are replacable. Anyone?
Also more general question, since all the panels will look like new, I really don't want to reuse original bolts/screws anywhere if I don't have to. Is there a good place to get new replacements, or do you have to go to hardware store and manually try to match what fits?
Old Jun 18, 2005 | 12:27 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
For GFX hardware, you are better off shopping at an auto body and paint supply. It's the best place to find body bolts, tapping screws, clips, push-in reatiners, etc.
If your old fasteners are rusty, I would replace them.
Old Jun 18, 2005 | 09:15 AM
VILeninDM's Avatar
then there is also rivets, but I can deal with those.
Those tapping screws is probably what I was most wondering about. I've tried taking one out, but they seem to be pretty solid in there. any tricks?
Also what about when there is a metal strip and it has 2 or 3 bolts going through it. Can those be replaced as one piece, or do I have to buy bolts and fabricate my own metal strip (drill holes and weld the bolts to it)
Old Jun 18, 2005 | 12:51 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
the self tapping scres are a dima a dozen at any hardware store, i use them for grounding alarm systems under the dash of cars, and probably have about 10,000 screws in my toolbox
ktthecarguy
Jul 5, 2020 11:46 AM
Bohemian
Aug 15, 2017 05:11 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
snakeshooter
Sep 7, 2015 11:15 AM
