what is this?
Old Jun 29, 2005 | 09:57 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
what is this?
there is a hole cut out, under my dash-pad, more specifically directly under the 2 center a/c vents. all the way to the front. there are 2 screws, one on each side (like something used to be there.) and a little tiny light bulb is tucked up in there (it doesnt work).
is this just a dome light of sorts and i am missing a lens or whats the deal? thanks guys.
Old Jun 29, 2005 | 10:13 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
its a courtesy light, suppost to go on when you open the door
Old Jun 29, 2005 | 10:22 PM
Car: 89 camaro rs
Engine: 305 tbi
awesome thanks. and im guessing it had a clear lens held on by those 2 screws?
Old Jun 29, 2005 | 10:55 PM
ChevyRacer's Avatar
Car: 86 Camaro Iroc-Z
Engine: 355 TPI
mines a white bult held by no screws hmmm....
wonder why your has em and mine dont...
Old Jun 30, 2005 | 09:02 AM
Car: 89 camaro rs
Engine: 305 tbi
hmm... ill just cut out a piece of plexi and drill a couple holes... after i get the bulb workin...
Old Jul 3, 2005 | 10:32 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
That little light lights up with the parking lights, and is made to shine down on the ashtray and the A/C controls to help you see them at night.
Sounds like you are just missing the little holder for the bulb.
Matt
Old Jul 3, 2005 | 11:02 PM
Gr89RS's Avatar
Car: '02 Z06
Any one have a pic of this?? Also one with it lit up would be awesome as well.
Old Jul 4, 2005 | 12:32 PM
Car: 89 camaro rs
Engine: 305 tbi
well, i couldnt find a replacement buld for it, but i got a small socket that uses a more common bulb, and i sauldered that in last night and used a piece of plexi for a cover. it dont look bad. but i don tknow if i like it that well. its a little bright too, so i think im gonna cover the plexi with sumthin. well thanks guys.
Old Jul 4, 2005 | 06:58 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
Any GM dealer will hav etha tbulb in stock and it wont be too bright like you said
Old Jul 12, 2005 | 08:57 PM
Car: 89 camaro rs
Engine: 305 tbi
duh.. i didnt think of that, its not too bad im used to it now
Old Jul 13, 2005 | 10:25 AM
ChevyRacer's Avatar
Engine: 355 TPI
I'm trying to customize my car in these areas.
I am replacing all the stock blubls and actually making them work. the stock bulbs were barely bright enough and after a while left them useless becuase the covers deteriorated.
I am adding more ultra bright LED lights in areas that could use them...
