Primer Question
Old Jul 1, 2005 | 01:48 AM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
Primer Question
im gonna primor my car, anyoen reccomd a certain brand and o certain way to do it? any tips on sanding?
thx guys
Old Jul 1, 2005 | 03:17 AM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
i've always had good experiances with ppg products, your not planning on leaving it in primer for a long time are you? Primer is porous and can hold moisture if its in wet weather alot...
as for the sanding just start marking spots off and filling and sanding till you have reached perfection...then shoot your primer
Old Jul 1, 2005 | 03:48 AM
Engine: V8 350 ci
well i was gonan primer and wait til i get enough money for a cheap paintjb like...500.00 or something.....i guess ill just primer 1 month within my paint job. :P thx for the reply
Old Jul 1, 2005 | 08:28 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i too am a fan of ppg. in my own opion its the best bang for the buck. i have also used and like standox and sikkens primers. very expensive. as stated above, primer is porous and can hold moisture. if you want to prime it and still be able to use it is all kinds of weather then shoot it with sealer. if you are stripping it down to bare metal than you should really use epoxy primer.
Old Jul 1, 2005 | 10:53 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
it sounds like your going in the wrong direction. check out 'project resurection; 7 threads, total repaint it covers all steps of prep and paint.
you cannot drive your car in primer and still paint it. the primer will be contamanated and paint will not adhere properly.
you need to get the same brand primer that the paint shop is using for paint. so if the use dupont get dupont ppg get pgg ect..
check out resurection do a search it will come right up and then if you have any more question give another post here.
be glad to help.
jeff
JeffW's Avatar
Engine: 305 tpi LB9
ps where you located?
Old Jul 1, 2005 | 11:28 PM
Engine: V8 350 ci
tacoma, wa
Old Jul 2, 2005 | 12:02 AM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
You CAN drive w/ primer on your caR, although its not recomended, and there is certain steps you can take to acomphish it
:NOTE:
There is many types of primer.
The one that our shop used was the Euro2K Primer from Dupont.
That one you can use and drive in weather.Although you still have to wet sand and put down sealer, before you shot your paint.
Sealer- Its the same thing as primer. you just mix it as a different ratio with the activator. it is alot "wetter".
That all should be fine. But just check w/ paint store and ask them which one would be better for your application. There is a automotive paint company in Tacoma called "wesco".
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
