Removing the dome light?
Old Jul 11, 2005 | 12:31 AM
ladyfirebird's Avatar
Car: 94 Firebird
Engine: 3.4
How do you remove the dome light? I know, silly question. I need to take it out so I can remove the headliner to recover it. Thanks.
Old Jul 11, 2005 | 02:56 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
There are two small round washer type pieces that slide over the little pins which are screwed into the roof, sometimes needlenose pliers or wire cutters are useful for grabbing them, but often you tear them up, probably cheap to replace from GM. The other way I have found that works good is to use a cordless drill, run the chuck down on each pin and tighten it up good, then run the drill in reverse, removing the pin with the little washer-clip with it.
1992CamaroGirl
Dec 25, 2017 08:45 PM
Omega
Aug 10, 2015 12:46 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 8, 2015 07:09 PM
