A couple fixes...
Old Jul 14, 2005 | 12:04 AM
guzba's Avatar
Car: 89 Firebird Formula
Transmission: Stock 5 Speed
A couple fixes...
Hey Everyone, I'm new a new member but ive been reading the forums for some time now. It's awesome having all this information on the vehicles available to me but i have a few questions on some things i havent seen.
Firstly I have this problem, (Pic Below) the plastic is peeling away from the shift plate and i was wondering what the best way to go about fixing it would be?
PIC:
http://www.cardomain.com/ride/1730437
My other problem is on the drivers side the plastic under the door has cracked and broken off near the back, i have all the peices and was wondering how i would go about putting it back together?
PIC:
http://www.cardomain.com/ride/1730437 (same as other one)
Thanks for all the help!
Old Jul 14, 2005 | 12:07 AM
crazycrocket's Avatar
Car: 1985 camaro
cheap fix, epoxy glue, or try and melt the plastic together. Proper fix (probably want to do this since it gets stepped on alot) replace it.
Old Jul 14, 2005 | 12:13 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'd replace the plastic in the door. Probably easy to find at a junkyard or ebay. Epoxy should work on the center console though.
Old Jul 14, 2005 | 12:14 AM
guzba's Avatar
Wow quick responses! thanks guys, so just epoxy the center back on like glue huh? sounds like fun and ill start looking for a new plastic peice! Thanks much!
Old Jul 15, 2005 | 02:28 AM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
so vise grips wraped in towels on loose enough not to damage but hard enough to make it hold and that 2 part epoxy u mix together? will the heat effect it in the summer?
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Linson
Oct 1, 2015 09:50 PM
