Shift knob wont go on.
Old Jul 30, 2005 | 04:01 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
Shift **** wont go on.
I bought a new shift **** from classic industries, but it will not slide all the way down onto my shifter (700r4). The shift **** is from a 91-92 camaro. Any reason it wont fit on my car (1986) ?
Old Jul 30, 2005 | 04:47 PM
Stevo's Avatar
Car: Pair of 92 Z28s
it should fit? try some kind of lube whether it be like white lithium or just some wd40
could be sticking i dunno
Old Jul 30, 2005 | 04:50 PM
UnderKule's Avatar
Car: 91' RS Camaro, 05' Stratus, 02 quad cab Dakota
Engine: 305 in the Camaro
not to sound stupid but did you see if the retainer was in the shift ***? That could pose a problem trying to install it. Other than that i like the Lube IDEA
J.P.
Old Jul 30, 2005 | 04:56 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
If I look down into where the shifter slides into the ****, it looks like there are two small clips on the inner side walls of it, but they look like they are meant to be there, and not move?
Old Jul 30, 2005 | 09:16 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Please don't tell me that's the retainer clip. Look at the front of the shift **** and see if there's a little clip (kinda looks like a staple) and pry that out. You had to have done the same thing to get the old one off.
Old Jul 31, 2005 | 09:32 AM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
no there is no clip in the front of it. This is why I cannot figure it out. I can rip apart a motor but this fockin shiftknob is a damn project.
Old Jul 31, 2005 | 09:40 AM
UnderKule's Avatar
If thi sis a brand new ****, sometimes that retainer is put in there before it is covered and although it looks like the retainer is not there. dig in there with a small screw driver or get a set of needle nose and try to move whatever it is that you said was in there. If any thing just rip out what is obstructing you, put it on and insert the retainer. If the **** is loose send it back to the company and get a new one. Or give me your address and i'll ship you one.
Old Aug 3, 2005 | 07:37 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Correct me if I'm wrong here but didn't the '86 Camaro originally come with the round ball shift **** and the '91-92 come with the square shift ****?
In which case, you would need to install a '87-92 Camaro or '84-92 Firebird shifter assembly to install the later style ****.
Old Aug 5, 2005 | 02:43 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
here is me correcting you
both shifters are the same
Old Aug 5, 2005 | 04:02 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
maybe he has it upside down
Old Aug 5, 2005 | 12:02 PM
Dens71TA's Avatar
NO, they are *NOT*. The '82-86 Camaro shifter is designed for a snap ring and and the "rod" that the button is attached to is retained into the shifter. This is what is required for all the Knight Rider freaks to install the '82 Firebird shift **** into 4-speed auto Firebirds that came with the T-handle.
The 87-92 Camaro shifter is the same as the 84-92 Firebird shifter(cost cutting by GM?) which is made for the U-clip and the "rod" just sits in the shifter and is held in my the shift ****.
Compare the two and you will see the difference.
Old Aug 5, 2005 | 04:15 PM
UnderKule's Avatar
I'm just posting my experience, i'm not getting into a challange of wits..... but i just took a shifter out of a 83' and put it in a 92' and everything is fine. The mechanical workings of the shifter work the same. You are right about the snap ring but the v-clip slid straight through and is retaining the new style handle where the snap ring was sitting.
J.P.
So you are both kinda right in a sense.
Old Aug 6, 2005 | 01:13 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
If you pull off the button, take off the shifter **** and look at the shaft, you will notice that the shaft is "notched" a certain way. My camaro has a notch on the drivers side that is wide, and accomodates the round **** with a wide tang on it. When you push the **** down you have to positon that tang into that notch (think of your girlfriend).
Some of the automatics have two notches, one on each side, and have smaller tangs on BOTH sides (driver and passenger). Obviously, if you try to put the wrong **** on, that extra tang is going to hit the shaft lip and keep it from going down. Look inside the original **** and see how many tangs or look at your shaft on the shifter and see if it just has one notch on the drivers side like mine (1986). I ran into a similiar problem when i pulled one off a junked car and it wouldnt fit.
Old Aug 6, 2005 | 01:19 AM
Lucid's Avatar
Sorry, i just figured out what you meant by clips. Those are the tangs i was talking about, they point in towards the middle, and they secure the **** in the shaft so it wont spin. If you have two of them, you probably have the wrong ****.
Old Aug 6, 2005 | 03:06 AM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
Re: Shift **** wont go on.
Lucid
look at the shaft
Lots of subliminal messages in this topic
Old Aug 6, 2005 | 04:28 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
yep must be wrong ****, I was under the impression the **** would fit all the cars. Gonna just ship it back. Dont really matter since I am building a new drivetrain, so I should prolly just get a megashifter.
Old Aug 11, 2005 | 02:09 PM
JDud's Avatar
I am trying to figure out how to take my **** off right now and looking at this thread, I am sure one of you can tell me what I am overlooking....
I have an 86 IROC with the round ball shifter on the 700R4. I can't see any clip/staple and no set screw....and it doesn't seem to just pull off.
What do I need to do to get this thing off?
Old Aug 11, 2005 | 05:02 PM
aerosmithr0cker's Avatar
Car: 1991 Z28 clone & 1985 Fiero 2M4
Engine: 305 TPI (In Progress, Camaro) & 2.5L 4 cyl soon to be 3.4
Transmission: 700R4 (Camaro) & Isuzu 5 speed (Fiero)
pull out the button on the top of the shifter and look down you will see a snap ring remove that pull ball off simple as that.
Old Aug 11, 2005 | 11:37 PM
venom's Avatar
Car: 1992 RS
Engine: 305tbi
Axle/Gears: 3.08
Exactly, well put Lucid. When I ripped the Megashifter out of my 92, the only replacement shifter I had was from my parts car 86 Z28. So until I can get a shifter assembly from a 87-92 Camaro, I just run without a shift ****
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
58mark
Sep 21, 2015 07:21 PM
armybyrd
Sep 16, 2015 07:00 AM
