C@C T tops with roof console?
Old Aug 26, 2005 | 06:42 AM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Hi
I just bought a C@C t top camaro. I was wondering if I can put in a roof console in between the C@C tops. Has anyone with a C@C put a roof console in? I would like to know if it will go in there before I go and buy a roof console.
Thanks guys
Speedmachine
Old Aug 26, 2005 | 10:25 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
What the heck's a C@C T-top Camaro?
JamesC
Old Aug 26, 2005 | 07:15 PM
Car: 1989 IROC-Z
Engine: 346 LS6
C@C is a company that put t tops in hard top camaros that they bought from GM and then sold them. [or something like that]. They arent exactly the same as factory GM ones though. Thats why I not sure if I can put a roof console in or not
Speedmachine
Old Aug 26, 2005 | 08:05 PM
JamesC's Avatar
Most cars, hard top or T-top, were drilled for the overhead console. I assume you'll need the hard-top version. Check the following link:
https://www.thirdgen.org/techbb2/sho...threadid=99782
JamesC
Old Aug 27, 2005 | 01:37 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Speedmachine
YES,My 84Z came with the O.H.roof console & has the C&Cs.
Old Aug 27, 2005 | 04:32 PM
sinister12c's Avatar
Car: 1989 Iroc-z
Engine: 5.7 TPI w/ZZ3 H.O. camshaft and alot of other enigine mods.
yes the roof console will work, will need to get the four mounting studs, they are self tapping. will also need wire harness for the dome light, and front map light.
Old Aug 27, 2005 | 05:54 PM
TuOrZ's Avatar
yup as said above
you will need those studs but otherwise it's pretty simple. I've done it on my TA.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
angel2794
Sep 8, 2015 06:22 PM
jimmy harris
Aug 31, 2015 03:09 PM
mav75
Aug 31, 2015 12:16 AM
