Pics of Both Types of Overhead Consoles
Old Apr 13, 2002 | 04:31 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've noted that some people are unaware of the differences between the two.
First, is the general shape. The coupe version is not only much more curved to fit the roofline but also has a reinforcement piece that slips under the headliner. Also, note that the area just in front of the dome light (the area that houses the flashlight) is wider.
Old Apr 13, 2002 | 04:34 PM
JamesC's Avatar
A second difference is how the console mounts. In the pic, the t-top version is on top.
The mounting 'slots' are not only in different positions but also slide onto the mounting studs from an opposite direction.
Old Apr 13, 2002 | 04:40 PM
JamesC's Avatar
Here's a better pic.
Old Apr 13, 2002 | 06:48 PM
91rsrider's Avatar
ive been wanting to get one of those for my t tops car.whats involved in installing one of those?what kid of hardware,if any is needed?and are they too hard to wire up?thanks!
Old Apr 13, 2002 | 07:01 PM
JamesC's Avatar
Check the tech articles for installation, which is straightforward (In my 85 IROC, for example, the holes were pre-drilled for the mounting hardware. I have several consoles, complete and otherwise, that I'll list in the classifieds soon.
JamesC
Old Apr 14, 2002 | 12:46 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
So James, which one is which? Is the curved one for hard top or t-tops? I have 3 of em, and theyre all straight ones, and I havent tried to put it on my GTA yet.
Old Apr 14, 2002 | 07:02 AM
JamesC's Avatar
The curved version fits the coupe/hardtop. I've read on this board that some guys have used the t-top version on a coupe, but given the differences, I would think that conversion would be very difficult.
JamesC
Old Apr 14, 2002 | 11:18 AM
scauffiel's Avatar
You should ask to add these pix and descriptions to the tech article.
Just an idea,
Steve
Old Apr 15, 2002 | 06:27 AM
JamesC's Avatar
Please note that in the first pic, there are no sun glass pouches. This area would be an excellent for mounting switches and/or switch boxes of varying sorts. Blocking off the hole for the flash light would provide yet another option.
JamesC
Old Apr 15, 2002 | 05:50 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Axle/Gears: 3.23 Posi
i am looking for the light and the retaining ring that goes in the front of the counsle. anyone have one or know where to get one? thanks.
Old Apr 18, 2002 | 06:40 AM
JamesC's Avatar
In answer to a couple of questions: The mounting hardware consists of four mounting studs, two screws (dome light), and one screw for ground. On the coupe version, the reinforcement piece goes in foam side up. The console can be mounted without removing the headliner. I made a simple cardboard cutout (put the console on the cardboard and draw around it, marking where all the holes should be), then used the two dome light screws as positioning guides. When you cut the headliner cloth, cut X's so that the material can be tucked under the headliner. Cut a little at a time and you can't really go wrong. Mine below.
JamesC
Old Apr 18, 2002 | 07:18 AM
USA-1's Avatar
Car: 1987 Iroc Z "Classic Roc"
Engine: 5.7 350
All of that posting and nobody mentioned the Pacman going on in the background?! :lala: Sorry dude, had to do it!
Old Apr 18, 2002 | 07:27 AM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
Hey, I would like to put one of those in my 89 RS. Would I have drill holes or are they already there for me, just have to get the console and cut the headliner? I got the domelight and thats it
Old Apr 18, 2002 | 07:38 AM
JamesC's Avatar
USA-1, PacMan rules (and you know it!).
Disturb, my IROC had the holes pre-drilled, so it should be a simple matter of finding an appropriate console, cutting the headliner, splicing a bit of wiring, and mounting. I'm unsure that I read you right, but the stock dome light is removed and replaced with the overhead, which contains a dome light.
JamesC
Old Apr 18, 2002 | 07:43 AM
Car: 89 Camaro RS
Engine: 2.8L V-6
Thanx for the info JamesC. How much would one of those cost new from a GM dealer? I'm not really fond of putting stuff out of junkyards in my car unless I'm POSITIVE that they are in excellent condition.
Old Apr 18, 2002 | 07:46 AM
JamesC's Avatar
Disturb,
Unfortunately, the overheads have long been discontinued from GM.
JamesC
Old Apr 18, 2002 | 10:20 AM
Greg Kuhlmann's Avatar
Its sooo easy! there are four little clips. and 2 screws that are in the Light cover... then the power clips right up... i could take mine down, run a mile, and have it back up in 6.5mins! theres nothing to it!
Old Apr 24, 2002 | 11:34 AM
JamesC's Avatar
Since I've had some e-mails, I'll run this through a final time.
JamesC
Old Apr 24, 2002 | 04:25 PM
JamesC's Avatar
Mounting hardware (the wiring can be seen above) and flash light.
JamesC
Old May 17, 2002 | 07:02 AM
JamesC's Avatar
Ok, here are the pics one more time.
JamesC
Old May 17, 2002 | 12:56 PM
LilJayV10's Avatar
Engine: 406 Roller
does anyony have the map light and the ring? if so, please email me. thanks
Old May 17, 2002 | 02:47 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
JamesC,
Do you still have any for a non T-top car? I will be making a good amount of money this summer (bout $3500 ) and would like to buy one from you if you have one in good condition, black, and would like to have the camaro flashlight if possible in it. thanx for any info.
Old May 17, 2002 | 05:01 PM
JamesC's Avatar
LilJayV10,
Check my ad in the classifieds for the map light.
Disturb,
I don't currently have a coupe version. I'll let you know if something should turn up.
JamesC
Old Aug 6, 2002 | 05:54 PM
JamesC's Avatar
tt for the sake of those who have questions.
JamesC
Old Feb 16, 2004 | 12:02 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Whoa, old thread. Does any one know where I can find these mounting bolts? The 4 silver ones that are used to hold the biggest part of the console in place?!?!? I bought a console, but it did not come with the hardware and I am now out of luck.Thanks fellas
Will
Old Feb 16, 2004 | 12:42 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
anyone in canada want to trade a hardtop console for a t-top console(my hardtop console, looking for a t-top console) it doesnt have the camaro flashlight, but u may keep yours if u have one...PM me if intersted
Old Feb 16, 2004 | 12:18 PM
VinJo87's Avatar
Car: 1988 Pontiac Firebird
Transmission: 700 R4
Good info...
Old Feb 18, 2004 | 03:02 PM
trendkiller's Avatar
Car: '89/'87/'82 "TransMaro L-81"
Engine: '82 Corvette L-81 (carbed)
Pac Man rocks!:rockon:
Old Feb 19, 2004 | 05:35 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Very informative (and old) post! I'd love to get my hands on one of these, but they seem to be hard to find!
Old Aug 27, 2005 | 09:18 AM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
James C
This puzzles me. I am almost 100% positive that GM manufactured all camaros as hardtop. Then the ones that were going to be a t top were cut out and a t top kit was put in. For convertables they just chopped the whole top off. So if all camaros were hartop in the begining why would there be two different roof consoles? Is it a difference in what year it was made or is it a Norwood Ohio plant vs. a Van Nuys California plant difference? Please give me some feed back on what you think about this.
Speedmachine
Old Aug 27, 2005 | 09:50 AM
LT1guy's Avatar
Car: 1987 Trans Am
Not sure why they did it, but GM wouldn't have tooled up two different consoles if it wasn't necessary.
I just scored another overhead console yesterday (for a hardtop)...missing the lamp and the flashlight, and the lens was brittle, but otherwise perfect. I think we're up to about 10-12 of them now! I always grab them, complete or not. Gotta love Pull-A-Part! Got a 5 speed shift plate from a bird and a Wonderbar in the same trip!
Old Aug 27, 2005 | 10:31 AM
JamesC's Avatar
The shapes of the overhead consoles reflect the rooflines: the curve of the hardtop and the more straight line of the T-top. GM produced both types of cars (the T-top is not a bastard child of the hardtop--nor is the vert, which I believe is structurally somewhat different than the hardtop/T-top cars).
By the way, this link is also on the FAQs page.
JamesC
Old Aug 27, 2005 | 07:16 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
Engine: V8 305 LB9 5.0 T.P.I
Transmission: THM 700 R4 Auto
I have a question for you. I have the overhead console in my 86 T/A. I currently have NO headliner, just metal.The console is up there, but no headliner. what is needed to install this console on a new headliner???
Old Aug 27, 2005 | 07:53 PM
JamesC's Avatar
Cut some holes.
https://www.thirdgen.org/newdesign/t...dconsole.shtml
JamesC
Old Dec 5, 2005 | 07:40 PM
irocstang's Avatar
Car: 86 IROC
Engine: 5.0
Transmission: 5 speed
I have a TTop overhead console for sale/trade
dont have pics right now. I got another one from an autowrecker because I was missing the tally dials. Ill have to go find it and look at it but i think thats it. Ther may be a small rip in the baggy too, im unsure. one thing i know is that it is missing the flashlight. In fact so is the newer one I got. IF anyone can dig me up a flashlight id glady trade the console for the flashlight. The console I have is not cracked or anything....looks decent....but is missing some components. post pics once i know theres interest....
Old Dec 20, 2005 | 10:10 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
does anyone have pictures of where to drill the holes for the screws to mount it for a t-top car btw. i just got one last night and i cant seem to figure out where/how to mount it.
Old Dec 20, 2005 | 10:15 AM
JamesC's Avatar
I suspect the holes have been pre-drilled.
JamesC
Old Dec 20, 2005 | 01:16 PM
Car: 88 IROC
i got it in there i looked at it late last night and it was kinda dark i found the holes today when i looked at it. i had to drill the holes out to make them bigger though
Old Mar 28, 2006 | 11:06 AM
coscob's Avatar
does the wire by the rearview mirror power the overhead console? 88gta
Old Mar 28, 2006 | 11:25 AM
JamesC's Avatar
Yes. The wires are probably white and orange.
JamesC
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
Fronzizzle
Sep 8, 2015 12:10 PM
scottmoyer
Sep 7, 2015 07:06 PM
Jetmeck
Sep 4, 2015 12:29 AM
