My GTA took a blow
Old Sep 13, 2005 | 05:39 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
My GTA took a blow
Well it seems Im not immune to body damage afterall. I know alot of our cars have been damaged lately, seems to be an ongoing trend around here, and now mine is one. I came out into an intersection when the guy to my left ran the redlightand hit my wheel straight on. It messed the fender, inner fender, door, and wheel up plus it bent my strut andbusted the centercap all up.I didnt notice that the alignment was so far off so all I did was exchange info and we both went on our way, I was already late for GM Training for work and I didnt want to mess around. I then left the scene and on my way to class I found out just hoow bad the damage was, the car wonders all over the road and the wheel is no longer anywhere near center. I have been in touch with my body guy and both his and my insurance the past couple days trying to get it all worked out and it looks like after my body guy gets a fax confirmation from he other guys insurance the repairs will finally begin. While the car is there they are gonna cut m a deal on a couple minor dings and stuff tahts in the car since they are already mixing paint up for it so it seems like things are gonna turn out ok in the end.
Old Sep 13, 2005 | 05:40 PM
meridius's Avatar
Another pic of it
Old Sep 13, 2005 | 05:41 PM
meridius's Avatar
and one just to show how bad it bent the strut, the steering wheel is straight.
Old Sep 13, 2005 | 05:45 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
Is the other wheel turned in that last pic also?
Old Sep 13, 2005 | 05:47 PM
meridius's Avatar
Nope, in all three pics the wheels are supposed to be straight, the right one is and so is the steering wheel.
Old Sep 13, 2005 | 05:48 PM
82knightrider's Avatar
Transmission: TH200C....700R4
looks like as far as exterior goes you just need a fender
Old Sep 13, 2005 | 05:50 PM
meridius's Avatar
yeah it needs a fender and the door took a hit too down by the GFX, kinda hard to see in those pics though.
Old Sep 15, 2005 | 03:14 PM
tagta189's Avatar
The exact same kind of hit happened to me recently,it bent my spindle assy which made my tire point outwards just like yours.My insurance scrapped the car.Fortunately I didn't give up so easily and its back in action again.Also the spindle assys are like $500 bucks new.I would almost guarantee yours is going to be bent,along with the strut assy.Good luck though,stay with it..
Old Sep 15, 2005 | 04:00 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Someone hit my car yesterday in my work parking lot scraped al the way down the drivers side and left. Im pretty sure its a woman that works downstairs from me ill be posting pics shortly.
Old Sep 15, 2005 | 07:23 PM
meridius's Avatar
I already had the insurance people come and look at the car and the body shop also looked at it and told me it was just the strut luckily. They are just awaiting confirmation from the insurance to start the work on the car so hopefully Ill have it back shortly.
Old Sep 15, 2005 | 07:45 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
With a hit like that I would seriously consider getting a second opinion. It's hard to believe that the only damage is to the strut. For the wheel to be that far out there would have to be damage to the tie rod or suspension arm. With the strut taking that much of a hit, the tower could very well be tweaked and the spot where the a arm meets the front framerail took a hit too so the frame could well be tweaked. Hopefully it's not that bad, but the impact was absorbed by all those points.
Old Sep 15, 2005 | 08:03 PM
meridius's Avatar
yeah I see your point but both the body shop and the insurance adjusters both looked at it and said the same thing so I doubt both are wrong, plus the body shop is where we outsource all our GM warrenty repairs so I know them pretty well.
Old Sep 15, 2005 | 09:40 PM
onebinky's Avatar
Most boneyards will have them for pretty cheap. I got a right one for $25 to remedy an elongated tierod end hole two summers ago.
Old Sep 15, 2005 | 09:56 PM
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
the other thing you want to look for is if it pushed in the mount of the a-arm, on the crossmember... check all the joints and rods, for safty... even if its bent a little make sure its replaced. i slid into a curb on ice i bent those parts on a third gen once... whooops.. nothing a couple hundred bucks cant remidy
Old Sep 16, 2005 | 06:03 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
oddly enough i just ad an f body at work wit a hit almost identical to yours. the spindle was messed up. i ended up replacein the spindle, control arm, strut, and steering. hope everything works out good for ya.
matt
Veaceonee
Sep 29, 2016 08:15 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
okfoz
Sep 15, 2015 05:22 PM
90formulaVortec
Sep 3, 2015 09:26 AM
