heat in console.
Old Sep 20, 2005 | 02:29 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
heat in console.
ok so ever since ive swapped the t56 in ive been getting alot of heat from it in my console and in turn its heating up my cd deck. and im getting worried about it. what can i do to keep the heat from coming in or lessen the impact on the stereo. ive put the shifter boot back.
Old Sep 20, 2005 | 02:59 PM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
CD decks can get pretty warm in their own right, are you sure it isn't the deck more than the transmission?
Best of luck,
Mark.
Old Sep 20, 2005 | 03:18 PM
7plagues's Avatar
no the trans puts off alot of heat and i never had this problem before the swap. like the shifter stick gets hot and so does my ebrake. so yep
Old Sep 20, 2005 | 04:15 PM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
I'd say figure out exactly where its coming from. get a trans cooler if you dont already have one, itll also help prolong the life on the trans. And make sure theres plenty of trans fluid and all that good stuff. I dont think it should get that hot where the shifter is actually hot. Might wanna ask some of the guys over on the trans board too.
Old Sep 20, 2005 | 04:44 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Mine get's really hot also.. I even put in the heavy rubber boot over the shifter and it still get's hot. I've never had any problems with the HU and its been a few years so I wouldnt worry about that, but I do hate having the heat on in the summer
Old Sep 20, 2005 | 05:06 PM
7plagues's Avatar
yea the trans cooler is gone.....umm...my t5 never had one....so yea... its filled with redline synthetic so at 10bux a quart i think its good. but yea! its like havin the damn heater on! LOL you guys know any good insolators or anything i could use around the boot or under the deck?
Old Sep 20, 2005 | 09:39 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
Mine gets hot too. I think it's normal.
Old Sep 20, 2005 | 10:55 PM
7plagues's Avatar
yea well whether its normal or not, doesnt fix how its making my deck get really really hot but i was wondering if others had a hot t56
Old Sep 21, 2005 | 02:58 PM
Firebat's Avatar
maybe put down some dynamat sound insulation around the tranny area under your console. i would think it insulates heat/cold also...
Old Sep 21, 2005 | 03:20 PM
87 B4Z TPI 5Spd's Avatar
My stock shifter on my T5 gets hot too midway down. But the top end at the **** never gets too bad. I think the hollow stock shifter dissipates heat better than a solid shifter.
And doesn't the T56 have a bigger case? If so I think less air gap between transmission and sheetmetal would cause more heat to radiate into the floor.
Old Sep 21, 2005 | 06:12 PM
7plagues's Avatar
that would be it probably i have a short shifter(solid). hmmm dynamat...thats some expensive stuff but ill look into it. thanx
Old Sep 21, 2005 | 06:14 PM
Firebat's Avatar
or even that insulation they sell at hardware stores that looks like dynamat might work. i dont know, its silver.
sheachopper
Jul 31, 2019 11:27 AM
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
