help turnsingnal and high beam switch
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
hello could someone please tell me how i get to my headlight turnsingnal switch.,.,on my 91 rs camaro i dont see no screws and ,.,.i realy need to get my high beems to work.,.,.,.,.,.,please help
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
your going to have to remove the steering wheel and go through the column there you will see how it is all put together. your 91 more likely has a SRS system in it (airbag) you need to go through a manual chitons will be fine to show how to remove the air bag safely. this is a big thing it could kill you if not careful. i had a freiend who did this so it one of my biggest concerns for anyone doing this job
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If the tilt mechanism is loose it can cause the turn signal/high beam switch to not align properly. Either way you'll have to go into the steering column and there's a tech article here on tightening the column that can walk you through.
Car: 1989 RS
Engine: 305 ci v8 LO3
Transmission: WC T5
I just change my lever and ill tell you what. Without looking at anything and thinking i was just gonna change it. There is a metal rod that runs down the steering column and fits to a plastic piece in the (close) to the steering wheel. If i didnt see how that fell apart i dont think i would of gotten it back together. There is def. a little bit to watch out for and def. be careful.
Hotrodboba400
Sep 2, 2015 07:28 PM
